Hello - looking at buying what seems to be a genuine 1978 Shovel with matching frame and engine numbers - only thing is that all the info I read says that the last 2 digits should be H8 but the bike numbers end J8, numbers being 8H5xxxxJ8. They don't seem to have been messed with and have the "stars" either-side - anyone any thoughts on this? Any advice appreciated as I would need to register it in the UK and do not want any problems.
8H = FLH 1200 Shrine bike and as bikedelic said H is Manufacture code used from 1970-79 J was used from 1980-on.
Look really close in person at #'s on neck and engine to see if the stamp font is the same. There are some good reproduction stamps for sale on ebay, someone could have altered the #'s.
My FL is a 70 model and the 8's almost look like hourglasses. Not sure the 80's model's used the same stamp font though. Look for some pics of other 80's model vin #'s so you have something to compare with.
Not saying they are messed with, the factory assembly line has been known to be quirky in the past.
Thanks gents - it is registered with the 8h prefix but half is missing and it is not the hourglass type like another in the vin so I guess it is actually 3h making it a flh80 classic from what I have gleaned from the forums etc. looks like these were only made in 1979 so would a final 8 on the vin match that model year or must it be a 9?
No joy googling - going to have to take another look and compare fonts as suggested and see if I can find the crankcase numbers which I understand should tell me the approx date at least. If they check out as being approx 1978/9 and engine/ frame numbers match and look ok then do you think Harley could have somehow stamped a J instead of a H or just an incompetent rebuilder?! Thanks again
I did find this dealership that says they will do a VIN check. Not sure if it will be US only or worldwide. Might be helpful. FREE VIN Safety Check
If the vin is questionable, better check it out and be sure. You can also call HD USA Customer Service at 1-800-258-2464
Related Threads
Harley Davidson Forums
1.8M posts
96.9K members
Since 2006
