I have some Showa air shocks that have an interference fit at the top of the shock. Shock mount is very close to the rear crash bar. There is a shoulder/gusset on one side and the air fitting on the other, so it interferes either way. However there is a good fit if you flip it over and put the air fitting on the bottom. Does an air shock care if it is installed upside down? The price was right and if I can run them upside down that would be cool.
