Hey guys, about a month ago I installed a new DK air cleaner and Do it yourself breather kit.
Well what a big difference.
For the first time I hit 100!!!!
Too fast....lol
But the power feels so much better.
My mpg went from 48 to 39.
Would a carb tune up help the mpg?
Thanks for reading, here's a couple pics of the ac.
It won't make much of a difference, except you'll feel better knowing your bike is tuned better. I changed my exhaust and air kit and then added a fuel management module and I lost about 6 mpg. The fuel management sets the bike to run a little rich so that's why I lost mpg. To me it's worth the added power and I like knowing my engine is running a little cooler.
Too fast....lol
Thanks for reading, here's a couple pics of the ac. View attachment 272706View attachment 272714View attachment 272722
Just back into the crankcase. Do`t think it will hurt anything.
It`s only an oil mist that is produced. Only drips when enough collects to form drops and overcome oil`s natural cling factor.
Was`t meant to start any crap (for once).
Just honestly have never seen one mounted that way.
can you do a couple of runs and check your plug for color like maybe go down a freeway nice and easy stay at the same speed using no more than 1/4 throttle hold it easy and dont go on and off the gas for this ut after 5 to 10 mile when you pull a plug out the color of the ceramic should be a tan color thats for the idle circuit I put a arlen ness big sucker stage 2 on my 1340 which is a 95 heritage and had to change all my jetting ended up using a 170 for the main a 22.5 pilot and needle in the middle position and the carby is a 42mm HSR so if you cant do the test or dont have time take for a dyno tune because pipes or air cleaner change or both may need differant jets and the air cleaner you use now has no restriction for air supply compared to the standard
If all you changed is the air filter, then except at WOT there is no noticeable change. At WOT the engine will tend to run a little lean. No real power or mileage changes except at WOT and full load.
Related Threads
Harley Davidson Forums
1.8M posts
96.6K members
Since 2006
