I know some of the videos out there show how to change the oil but most of those are for earlier model Sporties. I know throughout the years there are small variances mainly between where the oil drain plug is located on the Sporties. Since my bike is an '07 I figured I'd title the video as such.
Hope this helps someone out who might not be mechanically inclined, have a HD service manual or just learns better by video than reading. At any rate I made this to help you.
**Please do not comment on what type of oil is best used. There are a gazillion threads and posts on those debates. This video and thread is just to help someone learn what to do in order the change their engine oil.
(Note: this video was recorded in HD so if you need to see it in 720p it is available from the youtube dropdown)
Nice instructional video, I know you meant quarts not liters but that's cool. Thank you for taking the time to show people this simple task that otherwise would cost them a pretty nickel to have dona at a dealership. The more you work on your own machine the more you enjoy it.
Yup according to XLF that is correct for 04+. HD admits to a typo/misprint in the service manual for 04+ Sporties to it not being 3.6 qts.
Just to clarify should anyone else see my vid I never go exactly by what any manual says in terms of how much oil. I begin to add oil to just around the halfway mark, no higher on a cold engine. Then warm the engine up by letting it run for at least 10 minutes. Check oil level again and add til it's just shy of being topped off (a little more than 3/4 full). Adding it too high will cause oil blow-by issues I've heard. So I keep it just shy of being to the top line/mark.
i also slide a piece of thin cardboard under filter before removal long enough to clear frame to drain spent oil into drain pan. keeps oil off motor & frame.:2cents
Very nice video, but I would like to see you shoot it again changing one step. That was horrendous watching all that oil spill over and down the motor needlessly. A simple one quart plastic milk jug does wonders with a little trimming and can be reused again and again.
Another tip...throw those cloth shop rags in the garbage where they belong. These are the only towels which should come near an engine.
I do not think there is a real need to re-shoot the vid its a good effort and you show the logical next step in keeping the oil off your engine n frame...good on both of you.
My point was the OP wiped the interior surface of the oil filter as well as the dipstick and commented on all the lint left behind. Shop rags need to be delegated to wiping floors and nothing more...just having them available invites use.
Excellent video, excellent additional comments, thanks for sharing and saving a fellow some money, goodonya all!
Related Threads
Harley Davidson Forums
1.8M posts
96.6K members
Since 2006
