Thanks for the info, but i need some clarification. Being new to harleys, does the mms ean i need a power commander or just have a download put into the stock system.
You could go either way. Just a DL will still leave it running a little lean tho. Using a PowerCommander will allow you to set the air/fuel to a richer level .
If you have no plans to ever do anything else to the motor, the DL is the cheapest way to go, and it'll work fine .
Ok. That helps alot. I think ill plan ahead and go with the power commander while its in the shop. Just in case i want to do more in the future.... Thanks for all the help.
If you can afford to add the Autotuner to the PCV, you'll never need to remap for future mods, elevation changes, riding conditions, etc. I have not yet added it to my PCV, but someday.
Related Threads
Harley Davidson Forums
1.8M posts
96.6K members
Since 2006
