I have done this in other forums, being that this is the first HD forum I joined I thought I would do the same here... hope these threads help other newbies with their diy's...
Parts needed:
Heritage Style Handlebar - Satin Black - 55864-09 $61.20
Twist Grip Sensor Kit - 32310-08 $70.15 (not needed if you are careful of the old part when removing from stock bar)
Tools Needed:
Torx T30
Torx T40
7/8" Open wrench
Front fairing needs to come out to makes things easier... some will say that you can do this without taking out the fairing. I don't see how or do not see why would you fight to install when removing the fairing and disconnecting the TBW cable since it makes this install soooo much easier...
Anyway, remove the fairing. Don't know how? Here you go:
Front fairing removal - 2011 RGC
Remove the speedometer housing.
You will see the cable coming out of the handlebar.
Once you identify the cable, follow it to the back, and disconnect it. You will have to cut a tie wrap that holds it together with the other cables.
Carefully pull the cable out of the fairing.
Remove levers and control housing and slide the grip straight out...
Now comes the fun part
Carefully slide out the TBW sensor and cable out... just pull it gently until it comes of the handlebar notches and then help the cable come out by pushing it from the bottom of the handle bar and pulling the sensor at the handlebar grip end. I hope that makes sense... basically do not only pull on the handlebar grip end without helping it by pushing the cable from the other end.
Parts needed:
Tools Needed:
Torx T30
Torx T40
7/8" Open wrench
