Hello All,
I need to replace my primary cover on my 2009 RoadKing Classic.
Attached are two primary covers one is from my 2009 that I am replacing with a 2010 cover (I think)... are these interchangeable as they both have different part numbers and a slight modification at the front of the inside cover (see photos).... Is this 'Mod or different type of case rib' used to direct primary oil over the front compensating sprocket and rotor assembly?
I have changed the comp sprocket and upgraded the rotor from stock, the cover fits but I can't see inside if there's any clearance issues between the comp sprocket and the inside cover and thought i'd ask for advice before finishing the task.
Standing by for comments or issues....
Thanks,
Aussie Ads..
Thanks,
Aussie Ads..
