Welding Chain Sissybar - Harley Davidson Forums: Harley Davidson Motorcycle Forum
post #1 of 95 (permalink) Old 07-05-2011, 09:56 PM Thread Starter
Gitchy some!
JayWV's Avatar
I seen a bike with a sissy bar that was made out of a normal chain, each link was welded together and it looked really good. Dude just welded the bottom links to 1/2 stock metal and slid that into a normal sissy bar bracket and painted it black. Well I want to do the same thing. I've had a mig welder for about a year and been messing around with it. Anyway has anyone done this? Any problems I may run into or any tips to make it easier? I'm thinking it may be tough to get the exact shape I'm looking for. Any help is much appreciated.
JayWV is offline
post #2 of 95 (permalink) Old 07-05-2011, 10:45 PM
make a layout jig on a sheet of plywood
make sure your chain is clean of oil
and you will have to move your ground a lot, I would think that it would be hard to carry ground thru all the links
Rockerbox1 is offline
post #3 of 95 (permalink) Old 07-06-2011, 01:17 AM
EVO RULER
moose49's Avatar
Ground first link weld will make ground from there!
*CONFORMITY IS JUST A SLOW FORM OF SUICIDE*
******SUPPORT YOUR LOCAL INVADERS*******
********RIP RUBBERDOWN RIDE FREE********
moose49 is offline
post #4 of 95 (permalink) Old 07-06-2011, 06:42 AM
good point
post #5 of 95 (permalink) Old 07-06-2011, 08:22 AM Thread Starter
Gitchy some!
JayWV's Avatar
Yeah that makes sense. I'm pretty new to the whole fabricating thing, when you say make a jig out of plywood your saying cut out a template of the exact dimensions of the sissy bar right? Or would I just draw the sissy bar dimensions on the plywood then lay the chain on that template and start welding? Thanks
JayWV is offline
post #6 of 95 (permalink) Old 07-06-2011, 08:27 AM
I would draw exactly what you want, and then go through an drive in a series of large nails, or put in a series of screws or bolts that forms the shape of what you want and holds the chain in place
post #7 of 95 (permalink) Old 07-06-2011, 08:51 AM Thread Starter
Gitchy some!
JayWV's Avatar
Ok I can dig it, that way it aint moving around so much and it keeps the shape I want. I figure the first time through each link I would tack it then go back through and weld each link completely right? Then I'll try and clean up the welds, paint it black and clear coat it.
JayWV is offline
post #8 of 95 (permalink) Old 07-06-2011, 10:05 AM
Negative Ghost Rider
Along the line of what RB says, you may wanna cut out some cardboard and mock it up on your scoot, height, angle, etc. May help cut down on some changes along the way.
Either way, at least it will have your own personal touch and you get the pride of knowing you did it yourself.
~ Humphrey Bogart
misinlink is online now
post #9 of 95 (permalink) Old 07-06-2011, 01:36 PM
git-r-did
and post pics. be cool to see a series of pics as you are building it, like a step by step tutorial
post #10 of 95 (permalink) Old 07-06-2011, 02:25 PM Thread Starter
Gitchy some!
JayWV's Avatar
Thanks for all the info. Yeah I'll try and get some pics on here of the progress.
JayWV is offline
