Old 08-24-2009, 06:18 PM   #1 (permalink)
Chris Garrett's Avatar
Primary still leaking
As some of you know, I have a sealed primary and I'm having trouble with leaking. I don't think the gasket is leaking. It seems to be coming from the back of the primary case. I presume there is a seal back there, but I cannot find the old hose connector fitting or the hole it was in. Is it visible from under the bike? I don't see it in the primary case either. Is it behind the clutch plates?
1982 FLH80.
Chris Garrett is offline   Reply With Quote
Old 08-29-2009, 12:48 PM   #2 (permalink)
senior citizen
SCHMIDTYS's Avatar
Did you find it ? There would be 2 from the best of my memory , the chain oiler and the return line . The oiler is at about the center of the inner primary and the return at the rear bottom just behind that stripped out drain plug !!!
Old 08-29-2009, 07:36 PM   #3 (permalink)
Yeah, I found it and it's not leaking. I had an issue with the drain plug stripping out on the primary. Just got that fixed. Now back to looking for the primary leak. I think it may be a seal in back of the case. I'll probably just wait until winter. I taking it all apart then to install new clutch, primary chain and seals.
1982 FLH80.
Old 08-31-2009, 09:09 PM   #4 (permalink)
Resident Choppaphile
ARBY's Avatar
Images: 10
Could it be leaking from between the inner primary and the engine case. There's a seal there too ya know. Make sure the bolts are tight.
ARBY
http://chopperville1.tripod.com
"The greatest crime of all is a wasted life."
ARBY is offline   Reply With Quote
Old 08-31-2009, 09:10 PM   #5 (permalink)
CHOPPA RIDN MADNESS
Badassbrutus's Avatar
Main shaft tranny seal.Very common.
Except riding my Sled.
Lifes journey is not to arrive at the grave safely
Old 08-31-2009, 09:13 PM   #6 (permalink)
ARBY's Avatar
Images: 10
Yeah, why didn't I think of that. I live with the problem daily!
So do those that ride behind me
ARBY
Old 08-31-2009, 09:22 PM   #7 (permalink)
CHOPPA RIDN MADNESS
Never lose ur way home..lol
Old 09-01-2009, 07:29 AM   #8 (permalink)
senior citizen
SCHMIDTYS's Avatar
Inner primary trans main shaft seal ... something to remember to do when you have it all apart for repairs . That primary wasn't designed to hold oil , it was designed to maintain vacuume . When you install the new seal put it in opposite of the way it is when you remove it ( backwards ) .
Old 09-01-2009, 08:29 AM   #9 (permalink)
Shovelhead
1984 FLHS's Avatar
Been there done that.................
1984 FLHS is offline   Reply With Quote
Old 09-01-2009, 12:27 PM   #10 (permalink)
Appalachian American
XDixiecratX's Avatar
Why is that ???
THE HERD # 0001
XDixiecratX is online now   Reply With Quote
vB code is On
