Early or Late year 1978????? - Harley Davidson Forums: Harley Davidson Motorcycle Forum
post #1 of 10 (permalink) Old 09-15-2011, 01:12 AM Thread Starter
Pistol_Pete's Avatar
How does one go about telling if your FXS is an early or late 1978?
I am new to this bike and trying to get a manual for the bike - I notice they are divided between 1970-1978 and 1978 1/2 - 84.
Pistol_Pete is offline
post #2 of 10 (permalink) Old 09-15-2011, 05:52 AM
In 1978, the FXS had points ignition. In 1978 1/2, they changed over to electronic ignition.
R.I.P. Rubberdown. 1971-2012
2005 E.G. Classic
S&S 510 cams
Baisley Oil pump spring
CYCO tensioners
V&H Fuelpak
SE 3.5" pipes
K&N filter
Fueling lifters
S&S adj pushrods
Swingarm stabilizer
Dave63 is offline
post #3 of 10 (permalink) Old 09-15-2011, 11:03 PM Thread Starter
right on, thanks!
post #4 of 10 (permalink) Old 09-16-2011, 05:09 AM
but thats not saying you don't have a bike that might have had points, but was converted to electronic ignition
Rockerbox1 is offline
post #5 of 10 (permalink) Old 09-16-2011, 05:30 AM
Not so. It depends on the ignition.
1978 was the first year for electronic ignition for HD, but it was only a magnetic sensor/pick-up, and still retained the timing advance weights behind the timing plate. In 1980 (I believe) it went to full electronic, including a module to make all changes to timeing, and deletion of the advance weights.
http://www.bikebandit.com/showschematic/m563sch183496
2005 E.G. Classic
S&S 510 cams
CYCO tensioners
V&H Fuelpak
SE 3.5" pipes
K&N filter
Fueling lifters
S&S adj pushrods
Swingarm stabilizer
Dave63 is offline
post #6 of 10 (permalink) Old 09-16-2011, 01:49 PM
Wasn't '78 1/2 also the first 80in Shovelhead?
74in juggs are different from 80in.
pb68slab is offline
post #7 of 10 (permalink) Old 09-16-2011, 02:11 PM
74" jugs: 10 fins
80" jugs: 9 fins
However, I thought they didn't come out with the 80" until 82-83.
2005 E.G. Classic
S&S 510 cams
CYCO tensioners
V&H Fuelpak
SE 3.5" pipes
K&N filter
Fueling lifters
S&S adj pushrods
Swingarm stabilizer
Dave63 is offline
post #8 of 10 (permalink) Old 09-16-2011, 05:17 PM
My late bro had a 1979 FLH and it was definately an 80in. Looking at a set of 1980 80in jugs , and they have a -78 casting number.
pb68slab is offline
post #9 of 10 (permalink) Old 09-16-2011, 06:24 PM
Good enuf fo me Keith!
2005 E.G. Classic
S&S 510 cams
CYCO tensioners
V&H Fuelpak
SE 3.5" pipes
K&N filter
Fueling lifters
S&S adj pushrods
Swingarm stabilizer
Dave63 is offline
post #10 of 10 (permalink) Old 09-16-2011, 06:37 PM
LYNYRD SKYNYRD's Avatar
That's right I had one for years 78 1/2
H.D. and me all the way
LYNYRD SKYNYRD is offline
