I have shotgun pipes on my shovel and when i take a right turn and get into a corner the pipes hit the road! Any solutions anyone??? (apart from the obvious of putting the bike back to its standard height). I spin out because i can see that if i turn into a corner to tighly on either side i may go arse up! There apears to be more room on the left side and I have not hit the primary cover yet!
cheers
Julian
Reason: made mistake with attachment
I ran a hardtail sporty for a lot of years. That use to happen to me. The bike was so low…
“How low was it?”
It was so low, it would scrape going over a cigarette pack...
Anyway, I took the front pipe (lowest one) and cut a 1/2" out between the first and second bend and welded it back together. No more scraping...
I had the same problem and thoughts with My 76 FLH,Found a set of Paugho pipes that went on like stock with one on each side without all the crossover contraptions and that solved that problem and they sounded real good too.Was`nt as cool as the two out on one side but if it comes down to dumping it in a corner or lookin cool?????
It was real neat though when doing a right hand corner in the night and sparks would fly.
My '84 FLH does that. I have cut the drag pipes down short which works, but I don't like them that short. I talked to a local muffler shop and he would have bent them to ride closer to the frame which is a good option. I like the idea from MrMarty, can you send the order info for those pipes? Thanks
