'50 Panhead - Page 2 - Harley Davidson Forums: Harley Davidson Motorcycle Forum
post #11 of 27 (permalink) Old 02-19-2012, 11:20 AM
Mickey D's Avatar
Very nice EL. Going to be a nice project.
Hell, I'd ride it like it is for a season.
Mickey D is offline
post #12 of 27 (permalink) Old 02-19-2012, 02:47 PM
Ms. Subtle
3OliveMartini's Avatar
gorgeous bike... i am envious for sure!
and welcome.. how lucky you are!
People are more violently opposed to fur than leather because it's safer to harass rich women than motorcycle gangs.
3OliveMartini is offline
post #13 of 27 (permalink) Old 02-23-2012, 12:27 PM Thread Starter
1st question
Okay, problem #1 solved. Fixed oil leak. My next project is to figure out why the exhaust pipe coming out of the rear cylinder is blueing out. Any ideas? Timing? Too lean?
ryanj6061 is offline
post #14 of 27 (permalink) Old 02-23-2012, 01:03 PM
Guitar NOT Gator
gtrman66's Avatar
Lean is a common cause for bluing. I would check for a leak around the intake to the rear cylinder. Spray carb cleaner at it while idling and see if the RPM's go up.
You "fixed" the leak on a Panhead? The only way to do that is drain the oil
2016 FLHTK - 18 miles and counting
2004 FXSTSI - 10,000 miles and counting
http://www.doolinband.com - the band!
Dr. Rick "Superman" Doolin 1970-2014. Miss you bro.
Proud member of the NTC (North Texas Crew)
gtrman66 is online now
post #15 of 27 (permalink) Old 02-23-2012, 01:20 PM Thread Starter
well...you know what I mean. I got to the bottom of an exessive leak. Thanks for the info.
post #16 of 27 (permalink) Old 02-23-2012, 02:11 PM
That bike has an automatic chain oiler.....it will "appear" to leak. The oiler is adjustable. The adjustment screw is on the oil pump. A lot of times, they come loose and will dump oil on the drive chain, flinging it forward looking like the Exxon Valdez hit your garage..... Check that first.
Secondly....that bike has a tin primary. If dropped once, or the screws are overtightened resulting in warped metal, they leak like a 90 year olds blader at a comedy show....... Most gaskets are also cork, which suck too..........
Get a manual for the bike. A general repair manual for panheads will work, but there's better ones out there.
R.I.P. Rubberdown. 1971-2012
2005 E.G. Classic
S&S 510 cams
Baisley Oil pump spring
CYCO tensioners
V&H Fuelpak
SE 3.5" pipes
K&N filter
Fueling lifters
S&S adj pushrods
Swingarm stabilizer
Dave63 is offline
post #17 of 27 (permalink) Old 02-23-2012, 03:28 PM
LilJo's Avatar
That's the first thought I had. Get it running and RIDE it.
Great thread man, and we'll all be lookin' forward to updates and pix along the way. What a project!
Ride In Peace, Rick "Rubberdown" Massey
Ride Forever Free, Larry Weaver
LilJo is offline
post #18 of 27 (permalink) Old 02-23-2012, 03:32 PM
Tucson_Tim is offline
post #19 of 27 (permalink) Old 02-24-2012, 12:48 PM Thread Starter
You're right about the oiler. I didn't know whether I had a bad gasket or what. Basically, it would slowly drip oil as it sat on the kickstand, bu when I picked it upright it would pour out in a steady stream. It just sat so long that the primary filled up, but it wouldn't reach the drain hole unless it was upright. I'll be tinkering with it this weekend a little, and I'll try to get a few more photos posted. In the mean time, any suggestions where I can find a new 6v h2 battery without paying $150 directly from Harley?
post #20 of 27 (permalink) Old 02-24-2012, 02:32 PM
Negative Ghost Rider
look here....
6-Volt Battery Model H2 | 350-108 | J&P Cycles
~ Humphrey Bogart
misinlink is online now
