Old 06-23-2009, 10:06 PM   #1 (permalink)
up2nogood69's Avatar
Running HOT
Hello all.
Finaly finished the top end on my 73 FLH and went for a ride.
Put about 45 miles on her. When I got home i hit it with a laser thermo and she read about 345 to 360.
What is "normal" for a shovel? And what to check out as a cause for running hot?
Thanks to all for the torque info...
up2nogood69 is offline   Reply With Quote
Old 06-29-2009, 04:36 PM   #2 (permalink)
What?
RubberDown's Avatar
HHhmmmm, I have nothing to compare that temp to.
Running hot = running lean. Check your plugs and see if that's the case......
"Lead paint chips are chewy and sweet."
"Double Secret Agent 00019 of the Herd"
"Official Herd Short Bus Driver"
"It's not my fault those women posed nude, but it would be an insult not to look at them now..... "
"When cannibals ate a missionary, they got a taste of religion."
"I saw weird stuff in that place last night. Weird, strange, sick, twisted, eerie, godless, evil stuff... and I want in." H. Simpson
RubberDown is offline   Reply With Quote
Old 06-29-2009, 04:37 PM   #3 (permalink)
HERD # 00029
gruss's Avatar
Images: 29
RD is correct-sounds lean to me as well, plugs need checked.
g
Rest in Peace my Brothers
gruss is offline   Reply With Quote
Old 06-29-2009, 08:24 PM   #4 (permalink)
Mentally unstable.
Look at the plugs and see if it's lean. Items that come to mind are intake leaks.
If the plugs are good, the I have to wonder about ring gap, or oiling issues.
First check the plugs......
HERD meber #10
Old 06-30-2009, 06:23 AM   #5 (permalink)
Eleft36's Avatar
Originally Posted by up2nogood69 View Post
Hello all.
Not sure about your bike, mine stock FSXTC '07 that would be normal if checked close to the spark plug.
The "over heating" reference needs to be related to a factual set of data.
"Over heating" as to what?
Combustion alone is the source of heat that creates power, usually 450* to 580*.
The "air cooled" engine is designed to cool with external "air" flow. Heat naturally goes to cool, even at 100* ambient, the cooler air is 350* to 480* cooler than the combustion a 1/4" to 3/8" inside a vessel designed to radiate the heat into the ambient air surrounding it.
So where is the "over heating" ?
Al
V&H Slip Ons W/Double quiet baffles
Stock A/C Stock Heads Stock Cams
Mustang wide Touring Seat Stock Bars H.D. Oil Cooler
Fat Boy Bags H-D Windshield Thunder Max A/T
SE Compensator Kit
Eleft36 is offline   Reply With Quote
Old 06-30-2009, 07:28 AM   #6 (permalink)
Mentally unstable.
Not to mention, natural temps of cylinders breaking in will be slightly higher, due to more friction, until the rings have seated into the cylinder walls......
HERD meber #10
Old 07-01-2009, 11:17 PM   #7 (permalink)
responce
Thanks to all, will check plugs and check for intake leaks.
Rings are new, cylinders honed, gap set to specs from the 74 flh
"bible". Points cleaned and re gapped.
Carb could also be suspect?
Old 07-02-2009, 06:26 AM   #8 (permalink)
Eleft36's Avatar
If friction heat trumps combustion heat, a seizure is the next event.
I don't see there being a heat problem, with out previous data how can any decision be made?
Al
SE Compensator Kit
Old 07-16-2009, 07:33 PM   #9 (permalink)
Resident Choppaphile
ARBY's Avatar
Images: 10
Like everyone says, check the plugs. If they're bright white or speckled you're running lean.
Also check your timing. Timing is what keeps the rear jug cool!
ARBY
http://chopperville1.tripod.com
"The greatest crime of all is a wasted life."
ARBY is offline   Reply With Quote
Old 07-16-2009, 09:32 PM   #10 (permalink)
CHOPPA RIDN MADNESS
Badassbrutus's Avatar
always run it a little rich thats how I roll.
Except riding my Sled.
Lifes journey is not to arrive at the grave safely
Badassbrutus is online now   Reply With Quote
vB code is On
