Bracket removal
OK so I have had brackets and things added to a frame, but now I am removing some and that is a new experience. So what is the best way to accomplish this? I am trying to remove some seat mount brackets and others that are welded to the round section of the frame. I am also going to remove the tank cups that are welded to the side of the neck gusset. I am concerned mostly about unintentionally weakening the frame if I just go at it with a mini-grinder. I tried a cut-off wheel attached to my die grinder but there is still a pretty good stub and the weld left. Is if safe to grind the weld flat with the frame tube? No heat induced problems?
Search and ye shall find......the anwer to your exhaust question is in the exhaust forum.....whodda thunk it?
