Go Back   Harley Davidson Forums: Harley Davidson Motorcycle Forum > Specific Model Areas > Custom, Chopper General Discussions
Old 10-31-2007, 10:08 PM   #1 (permalink)
COB
GAZOO!'s Avatar
Images: 86
My XS-650 econo-bobber build
Well, I kinda started actually working toward a goal today. Most of the time with this thing it has been just stripping it down and trying to figure out just what I want to do. I am not 100% sure, but I am close to deciding to make a matching bobber to the Sportster only way on the cheap side.
Today I started grinding off brackets and mounts that I wont need. This is a new experience for me. I have made a few customs but always from parts I spec'd out. This is the first time I have hacked and grinded on a existing bike to the extent I am planning on.
I don't want to get too far too fast. It is a long winter here in Utah and I don't want to end up with Spring Fever because I finished all my projects too soon.
Search and ye shall find......the anwer to your exhaust question is in the exhaust forum.....whodda thunk it?
GAZOO! is offline   Reply With Quote
Old 10-31-2007, 11:00 PM   #2 (permalink)
2 Wheels = Therapy
Coonass's Avatar
Images: 5
Kewl! Are you gonna document various stages of the build for us? Huh? Huh? Are ya?
Coonass is offline   Reply With Quote
Old 11-01-2007, 12:15 AM   #3 (permalink)
Just passing thru
EZE RIDER's Avatar
Images: 124
Keep us posted....literally
RIDE ON!
2007 VRSCDX since
November 28 2006
Pics
EZE RIDER is offline   Reply With Quote
Old 11-01-2007, 12:34 AM   #4 (permalink)
COB
GAZOO!'s Avatar
Images: 86
I am roughly working from this bike. I was going to hardtail it but the cost started climbing, so I am going to leave it with a swing arm. I am trying to complete this bike for under $2k including the original cost of the bike which was $700. I have picked up a Sporty tank and fender off of flea-bay.
Of course there will be some Gazoo Green in there somewhere!
My Econo-Bobber inspiration
There are a lot of unknowns right now. I will probably remove the electric start and go kickstart only. This will allow me to use a much smaller battery, probably a little gel-cel, and to simplify the wiring. I want to make this as simple as possible. I have to look into Utah laws and see if I need electric turn signals and horn.
Old 11-01-2007, 08:58 PM   #5 (permalink)
COB
GAZOO!'s Avatar
Images: 86
I went out and bought a cutting wheel for the mini-grinder. The cut-off wheel on the die grinder is probably great for smaller things, but it is taking too long for the bigger brackets and mounts.
I went to the dentist today and have never had a more painful time. I am pretty sore and am cruising along on Lortabs. I think I will go out and mount the cutting wheel and if I don't feel too woozy try cutting off the center stand mounts.
Chat with you in a bit.
Old 11-01-2007, 10:32 PM   #6 (permalink)
COB
GAZOO!'s Avatar
Images: 86
Well now, that cut off wheel on the mini-grinder takes care of business!! I got all the brackets cut and the rear hoop that usually serves as a rear fender mount removed. I was able to grind down a bunch of stuff to level with the frame tubes before my toof started hurting and I decided to come in and watch Dexter.
I really don't have too much more to do before I completely strip the frame and send it out to be sand blasted. After that it will be easier to smooth out the spots where brackets and stuff were cut off.
The cold weather is coming so I will need to invest in a heater for my garage. It gets below 70 here for months and I can't paint below that so I am going to have to try and figure out some way of heating the garage without a flame so I can paint. We will see what works out.
Old 11-02-2007, 12:56 AM   #7 (permalink)
2 Wheels = Therapy
Coonass's Avatar
Images: 5
I've used a type of infrared heater in the machine shop. It looked like a bright as hell, weird colored flourescent light and worked really well. I think it was just like the one I linked:
http://www.infraredheaters.com/solaira2.htm
If included, it may push you just a tad over your budget. They were a little pricey if I recall correctly.
Old 11-02-2007, 01:58 AM   #8 (permalink)
COB
GAZOO!'s Avatar
Images: 86
I can run a propane heater then rent a ir one for when I need to paint. Thanks for the ideer.
Old 01-05-2008, 11:35 PM   #9 (permalink)
COB
GAZOO!'s Avatar
Images: 86
So I finally got around to cutting the rear off the ol Yammie. I hope to have the hardtail in place this coming week. Until then, the only thing holding all the frame geometry in place are the engine mount bolts.
I bought a plasma cutter pretty much for this job, but after experiementing I found the best thing for cutting this type of work was a Sawzall with a 18T blade. Cut right through, I was really surprised.
All the stuff on the cardboard is things I have cut off. It will give me plenty of material to practice welding on before I do the final weld on the hardtail.
I also built and engine stand for the little Yammie motor. Surprisingly I have sold quite a few of them on one of the forums that the 650 guys frequent.
Old 01-06-2008, 12:41 AM   #10 (permalink)
Just passing thru
EZE RIDER's Avatar
Images: 124
This is great! You are sorta inspiring me to do something like that one day. Keep it coming.
RIDE ON!
2007 VRSCDX since
November 28 2006
Pics
vB code is On
