WTF? What am I doing wrong? - Harley Davidson Forums: Harley Davidson Motorcycle Forum
 25Likes
post #1 of 34 (permalink) Old 01-02-2017, 02:57 PM Thread Starter
Themike13's Avatar
Gas tank overflow!
I have a Fat Bob split tank setup.
The trouble I am having is when I need to fill with gas. I fill the right tank and never open the left tank. But for some reason the left tank overflows every time. Gas begins seeping out of left gas cap rim. Not just a little, but a lot.
If I level the bike and look in both tanks, the left tank is always a touch higher and not level. Of course when I lean it back on the stand, gravity takes over and the angle of the bike forces gas to over flow out left cap.
If I siphon gas from left tank while bike is off stand and level, the left tank bubbles and seems to vacuum suck gas into the left tank. I siphoned gas about 2 liters from left tank to a point where I could put it in the stand and it not leak.
It appears both caps are vented. This might be part of the problem.
Themike13 is offline
post #2 of 34 (permalink) Old 01-02-2017, 03:17 PM
Asylum Inmate
bbally's Avatar
Plug the left hand tank port with a fuel gauge.
Themike13 likes this.
Don't be a Puss Sign up for Collision 2017 here
USMC Sgt 79-85
Malo periculosam, libertatem quam quietam servitutem
Western Colorado PGR
2003 VRSCA
2016 FLTRXS
AMA PAC Supporter
bbally is online now
post #3 of 34 (permalink) Old 01-02-2017, 03:19 PM
Ambassador
421Tripower's Avatar
Please introduce yourself in the New to community forum. We want to know where you're from? Pics are nice. And if you're going to stick around.
FrankenTrike and Themike13 like this.
421Tripower is offline
post #4 of 34 (permalink) Old 01-02-2017, 03:28 PM Thread Starter
Themike13's Avatar
Intro was the first thing I did before posting this. Thanks.
post #5 of 34 (permalink) Old 01-02-2017, 03:38 PM
OHEhsc's Avatar
Don't want to sound like a smart a** but have you tried filling from the left tank first? Either way, it does sound odd that the gas overflows so much coming from the right. bbally's suggestion sounds like a good one
Kainam likes this.
OHEhsc is online now
post #6 of 34 (permalink) Old 01-02-2017, 03:40 PM
candyman1340's Avatar
you do understand how gravity works I hope..... the gas flows to the carb because the gas caps are vented
put a piece of wood under the kickstand to raise the bike up a bit. There is also a kickstand wedge that can be installed if your bike leans too much
candyman1340 is online now
post #7 of 34 (permalink) Old 01-02-2017, 03:41 PM
Negative Ghost Rider
to me it sounds like a better seal is in order....but I just throwing darts in the dark...
~ Humphrey Bogart
misinlink is online now
post #8 of 34 (permalink) Old 01-02-2017, 03:43 PM
FritzHD's Avatar
How's the gasket around cap?
FritzHD is online now
post #9 of 34 (permalink) Old 01-02-2017, 03:54 PM
Lovin' every minute
Silverback's Avatar
Images: 14
My son's Fat Boy has dual tanks. He always fills the left tank first, caps it, and then fills the right tank. The left cap seal should not leak, so the gasket does appear to be defective. One other thing--far-fetched, maybe, but possible--a bad crossover hose with a bubble on the inside acting like a one-way valve. Check this by holding the bike vertical while up through the left filler neck and looking into the right filler neck to see if both tank levels rise at the same rate. Yeah, I know it sounds weird but I've seen this happen with old brake hoses. But I really think a new gasket on your left cap will get you straight.
"There's no sensation to compare with this
Suspended animation, a state of bliss
" --Pink Floyd
** This line seems to come to mind often while I'm riding.
"Men do not quit playing because they grow old. They grow old because they quit playing." --Oliver Wendell Holmes
"And miles to go before I sleep
...and miles to go before I sleep." -- Robert Frost
If you give up drinking, you don't live longer...it just seems longer
Silverback is online now
post #10 of 34 (permalink) Old 01-02-2017, 03:57 PM Thread Starter
Themike13's Avatar
