Go Back   Harley Davidson Forums: Harley Davidson Motorcycle Forum > Specific Model Areas > Custom, Chopper General Discussions
Old 08-10-2007, 05:51 PM   #1 (permalink)
BadgerOctane's Avatar
Images: 16
Gold Leafing 101, A Badger 'How-To'.
Hey all,
Its been a while since I'd written one of these and felt its long overdue. So here's some light reading and good pics.
I feel it fair to mention that this particular project came to me ‘third party’, and all the materials were provided for me per customer specifications, so that’s why its not an exact match, merely a ballpark comparison. I’ll start by showing you my reference materials, and really the only thing I had to go off of:
And here’s a better image of this 2007 FLHRSE CVO I found on the web:
So moving right along, we start with one of these, a fiberglass half-shell provided by the SuperSeer corporation. Here you can see I’ve already done my prep which included sanding the gel coat, washing and cleaning, applying a spray fill primer and a sealer, then wet sanding with 600 grit. As you can see its ready for the base to be applied:
And now is a great time to talk about that base. I didn’t have the actual colors used on the ‘07 I was imitating. So I used Harley Davidson Scarlet Red. This particular blend was available to me in a lacquer. Its important to mention that in most states, lacquers are rapidly becoming obsolete. Many of HD’s colors are crossing over into urethanes now and it’s a simple matter of changing the last digit of the prefix in the paint code. In short, 98603 = a lacquer, 98609 = a urethane. For this project I used HD paint number 98603 LZ.:
I laid down a nice even base as seen here:
Now I was told the actual bike had a (and I quote) “glittery effect” over the red. I took this to mean there was a pearl involved which is pretty typical for most factory customs. But the customer wanted something with a bit more “bling” to it, so I used House of Kolor UMF01 Ultra Mini Gold Flake. I mixed about an 1/8 of a teaspoon with a clear lacquer and applied it over the base. Its difficult to see it, but you can see it well in some of the other shots.:
After I allowed it to flash off I lightly scuffed the surface with 600 wet and applied an ample flow of intercoat clear. The clear is basically going to help smooth out my surface because the metal flakes are literally just that, tiny little metallic squares. They don’t always lay down flat, and I wanted something to help ‘bury’ them so they wouldn’t cause any issues with the gold leaf.
(continued)
http://www.badgerkustoms.com
BadgerOctane is offline   Reply With Quote
Old 08-10-2007, 05:52 PM   #2 (permalink)
Images: 16
I allowed my intercoat to flash off and then I once again sanded with 600 wet. I made sure to sand nice and evenly, this helps promote adhesion for future coats, and the gold leaf to be applied.
I then had to plot my design on the sides. Using fineline masking tape, I defined both the center line of the shell and a low base perimeter for which to gauge my symmetry.:
After this was done, I applied my masking material. In this case I relied on my trusty R-Tape which is a common transfer tape material used most often by sign makers. It has good tack qualities that leave no residue, and its re-positionable. Because I’m not spraying anything, I didn’t have to go through the thorough process of a full smoothing. I merely needed to set a decent space for which I’ll sketch my design (as seen here) and apply the size. Size is the glue used in the gold leafing process:
After sketching my design I had to go through the careful process of weeding. Weeding is basically just cutting out the design. I did this right on the shell because I’ve been doing this for a long time, and I know how NOT to cut through to the painted surface. Believe me you can ruin a great paint job if you cut too deep on your masking materials. I’d like to also mention that the good thing about the R-Tape is that I could have removed it, placed it on a smooth piece of plastic, glass, or metal and cut it there. I recommend using this technique if you’re just starting out. You can then replace your tape onto the surface to be painted, but after its cut it can be a little bit of a pain to reset it properly. Time was the main reason I opted to cut it in place.:
And here you can see it in more detail with the full design removed. I should also mention I did this on both sides.:
Now I did a free hand sketch on both sides and only lined everything up by eye. Granted it still came out very concentric, there’s a way to get your side to side designs 100% symmetrical and that is to simply use tracing paper on the finished sketch from one side. Apply a light coating of chalk to the traced image, flip it, lay it down on the other side and lightly retrace. When you remove the paper, your image is successfully transferred. Takes a little more time but it does guarantee your image match.
(continued)
Old 08-10-2007, 05:52 PM   #3 (permalink)
Images: 16
Ok so next I applied the size, Old World Art #802. There are many ways to apply this, ( i.e. brush, airbrush/spray, roller, etc.) as you can see here I chose a 1” brush for a quick and easy application.:
Here’s how it looks after application, sort of milky. It takes about 45-60 minutes for it to set up. Basically when its clear you should be about ready, it will almost seem too dry if you actually touch it, but believe me, it works.:
Here’s the leaf I used. It’s a composition, imitation gold leaf. I know it doesn’t match the variegated leaf on the bike, but again, the materials were provided to me for this one. I can’t complain. This particular brand came on sheets which made for ease of application. The leaf is loosely attached to a backing, simply place the leaf on the size, backing side up, and gently lift. The leaf is left in place, and if more is still sticking to the backing, just repeat the process until its all used. There’s little to no waste in this process.:
After I got all the leaf onto the surface I carefully ‘set’ it with a hand made tool. Just a wooden dowel with some felt wrapped cotton on the end. I carefully and evenly set the surface. Its best not to touch the leaf with your hands unless you’re very familiar with it. It can tear very easily and mess up your work if not careful, so tools like this are very useful. I did end up using a very light fingernail touch though because this project required a very defined flame edge and I wanted to make sure those tips were setting properly.
This is what it looked like after I had the leaf set.:
To insure good adhesion of the leaf, I allowed it to sit for 24 hours. I didn’t want to risk removing the R-Tape and lifting what had taken me a while to lay down. The next day, I was ready to use my swaffing brush to remove any excess leaf. it’s a soft brush, that I can use to gently wisp away any excess without damaging the leaf. The leaf is still very fragile even though dry, so this is important to just take your time and do it right. After this, I carefully and slowly removed the tape, revealing a very nicely set design with minimal jagged edges.:
I cleaned it up for a better look, and in this shot you can see the symmetry of the design is very appealing.:
After this I tacked off the shell to remove any little leaf particles from brushing and then carefully wiped the surface with wax/degreaser to clean any tape residue that might have shown through once I cleared again. It was then time to apply another intercoat clear.:
So that’s gold leafing in a nutshell. From here I’ll sand one more time, apply my pinstriped edge bordering the leafed flames, ( HD basecoat, 98609 BNR) and apply two topcoat clears. Then its back to SuperSeer where they’ll finish up the shell with the liner, harness, beading, vents, etc.
I’ll try to grab some finished pics when I can. That’s all for now, hope you’ve enjoyed it.
Badger
Old 08-10-2007, 08:15 PM   #4 (permalink)
2007 Ultra Classic
Dinero No Mas's Avatar
Thanks Badger. That was great and I learned something.
Dinero No Mas is offline   Reply With Quote
Old 08-11-2007, 01:38 AM   #5 (permalink)
Just passing thru
EZE RIDER's Avatar
Images: 124
Nice work. I enjoyed reading this post. Thanks.
RIDE ON!
2007 VRSCDX since
November 28 2006
Pics
EZE RIDER is online now   Reply With Quote
Old 08-11-2007, 04:56 PM   #6 (permalink)
Images: 16
Thanks,
I'm working on a '73 Sporty restoration project for a customer right now. The factory decals for it are being shipped to me from AZ, the paint is in stock and I'll make sure to grab some pics to post.
In the next few months I'll be doing another frame build and also some custom shaped tins in the shop. I'll make sure to do another How-To of those to post as well.
Thanks again,
Badger
Old 08-11-2007, 11:09 PM   #7 (permalink)
DiamondLil's Avatar
Images: 123
That is vey nice! Thanks for posting. It is just the sort of thing needed for my anthracite colored Shoe. How would this process change or could it be done on a already factory finished helmet?
http://www.moviephotoforums.com/phot...IMG_0886-2.jpg
2008 VRSCAW V-Rod Custom 0005/1200
“Wit has truth in it; wisecracking is simply calisthenics with words.” Dorothy Parker
12-07-2006
DiamondLil is offline   Reply With Quote
Old 08-11-2007, 11:21 PM   #8 (permalink)
Images: 16
It can be done on most factory finishes. A few extra steps are added but for the most part the rest is quite similar.
Badger
Old 08-12-2007, 12:32 AM   #9 (permalink)
Adminimum
sfarson's Avatar
Badger... This is excellent. I thought I'd left a post earlier on this, but can't find. With us in the same area, I need to keep you in mind for some projects!
Steve
sfarson is offline   Reply With Quote
Old 08-12-2007, 05:36 AM   #10 (permalink)
ΜΟλΩΝ λΑβέ
Kainam's Avatar
Images: 109
Very nice, looking forward to your future how-tos.
Originally Posted by Representative Suzanna Gratia Hupp
"How a politician stands on the Second Amendment tells you how he or she views you as an individual... as a trustworthy and productive citizen, or as part of an unruly crowd that needs to be lorded over, controlled, supervised, and taken care of."
Originally Posted by Thomas Jefferson
"Tyranny is defined as that which is legal for the government but illegal for the citizenry."
'05 Carbed Night Train
111 rwhp, 112 rwtq
Kainam is online now   Reply With Quote
vB code is On
