Can I put a wide glide gas tank on my fxd? - Harley Davidson Forums: Harley Davidson Motorcycle Forum
post #1 of 8 (permalink) Old 12-21-2009, 10:39 AM Thread Starter
I'm sick of deciding where to put my damn speedo. If. Buy a wideglide set of tins. Will they fit on my fxd? There is a local guy with a tin set off a 2003 100th anniv. Wide glide, silver and black. This way I can put the speedo in the gas tank console.
Next question. Is the speedo the same on all the bikes? So all I have to buy is the dash? And it should drop right in? And can i relocate my ignition to the console too?
Maybe someone has done this and can give me a parts list of everything I'll need??
Eric The Welder is offline
post #2 of 8 (permalink) Old 12-21-2009, 10:49 AM Thread Starter
Also my bike is a 99 fxd. So the tank should be the same up to 03 right? They changed it in 04?
post #3 of 8 (permalink) Old 12-21-2009, 10:52 AM
You can make the tanks fit the FXD, but you may have to make different mounts, as I believe the frames may be different. I know the speedo is NOT the same. The speedo for the wideglide is larger in diameter the your FXD, and fits in a "dash" panel that you'll need to get as well. You'll also need to make a harness to bring electrics up into the dash, or figure where they come off yours and run them up under the frame and tank to the dash. Keeping in mind, the WG's ignition is in that dash too, as you stated. You can run the ignition wires from the plug under your seat (3 wires total) to up under the dash and go to a new ignition switch and maybe get it keyed to your original key. The new ignition switch for the WG will accept them in the right configuration.
The hardest part will be making the mounts to look like it came that way. It shouldn't be too hard.
R.I.P. Rubberdown. 1971-2012
2005 E.G. Classic
S&S 510 cams
Baisley Oil pump spring
CYCO tensioners
V&H Fuelpak
SE 3.5" pipes
K&N filter
Fueling lifters
S&S adj pushrods
Swingarm stabilizer
Dave63 is offline
post #4 of 8 (permalink) Old 12-21-2009, 10:54 AM
99 FXD tanks were the same (except color) from 95-03. Mines a 1995 with a 1999 tank on it.
You'll lose your gas guage in the swap.
2005 E.G. Classic
S&S 510 cams
CYCO tensioners
V&H Fuelpak
SE 3.5" pipes
K&N filter
Fueling lifters
S&S adj pushrods
Swingarm stabilizer
Dave63 is offline
post #5 of 8 (permalink) Old 12-21-2009, 02:01 PM Thread Starter
I thought the tank would fit without modification. The frame should be the same on a fxd and wideglide. I will buy the dash. I'll have to find a speedo because I thought they were the same size. Bit no biggie.
post #6 of 8 (permalink) Old 03-06-2010, 06:52 AM
Images: 3
2004 FXDWG speedo
I have a 2004 speedo that I do not need 8000 plus miles
moriseiki2002 is offline
post #7 of 8 (permalink) Old 03-06-2010, 06:59 AM
ummm, kind sir, this thread is over two months old, he has since completed his bike
Rockerbox1 is offline
post #8 of 8 (permalink) Old 03-07-2010, 10:24 PM Thread Starter
i dont know about "completed" lol but this perticular project is indeed finished. thanks though.
