Primary noise?? - Harley Davidson Forums: Harley Davidson Motorcycle Forum
post #1 of 8 (permalink) Old 03-25-2014, 09:43 PM Thread Starter
deetek's Avatar
Primary noise??
Ok, serious question for you pros out there. I just noticed some noise coming from the primary area. At idle I hear a rather loud spinning/rattling noise that stops when I engage my clutch. When I release the clutch it starts making that same noise again. It's louder than normal I think because I didn't notice it before over the loud pipes. But now it is pretty noticable. You can even hear it when I'm riding and again it quiets down when I engage the clutch lever. But it shifts and rides fine.. Please help. Sounds as though there is no fluid in the primary, which I'm sure there is.
Any ideas?? Thanks!
dEEtEk
deetek is offline
post #2 of 8 (permalink) Old 03-25-2014, 10:55 PM
Could be the compensator loose, or the nut that holds the clutch basket. Clutch basket nut can be checked via the derby cover removal only. The compensator nut can only be checked after the primary cover is removed.
Clutch nut is reverse thread. (Left to tighten, right to loosen)
R.I.P. Rubberdown. 1971-2012
2005 E.G. Classic
S&S 510 cams
Baisley Oil pump spring
CYCO tensioners
V&H Fuelpak
SE 3.5" pipes
K&N filter
Fueling lifters
S&S adj pushrods
Swingarm stabilizer
Dave63 is offline
post #3 of 8 (permalink) Old 03-26-2014, 03:09 PM Thread Starter
deetek's Avatar
thanks Dave! I'll check that out ASAP!
dEEtEk
deetek is offline
post #4 of 8 (permalink) Old 03-26-2014, 03:21 PM
09 Softail C's Avatar
When I had that noise it was the inner primary bearing...........
'17 FLHXS Street Glide Special
'14 VRSCDX Night Rod
'14 Softail Slim (traded for '14 VSRCDX)
'07 Night Rod Special (Totaled in July '11)
'08 Nightster XL 1200N (Traded)
'09 Softail Custom Traded 10/13
'09 Springer CVO Screaming Eagle
'10 CVO Screaming Eagle Softail Custom Convertible
'11 Nightster XL 1200N (Traded for CVO)
'07 Thunder Mountain Chopper (w/ 103 HD Screaming Eagle) Traded 10/13
09 Softail C is offline
post #5 of 8 (permalink) Old 03-27-2014, 06:08 PM Thread Starter
deetek's Avatar
Just found out that it is was my inner primary bearing. Good thing is is that it was a recall on all 06 Dynas. She's at the dealership now getting all redone, free of charge, with the correct parts so that it doesn't happen again. Awesome!
Plus they found another recall for the battery mount that will be corrected as well.
Thanks for the help, guys!
dEEtEk
deetek is offline
post #6 of 8 (permalink) Old 03-27-2014, 06:13 PM
Good deal...... didn't know it was a 2006 Dyna. One year only inner primary bearing. Bad design compared to others. Glad to hear it all worked out.
Sent from Motorcycle.com App
2005 E.G. Classic
S&S 510 cams
CYCO tensioners
V&H Fuelpak
SE 3.5" pipes
K&N filter
Fueling lifters
S&S adj pushrods
Swingarm stabilizer
Dave63 is offline
post #7 of 8 (permalink) Old 04-01-2014, 07:08 PM
Good Deal is right. Mine cost me $$$$. No recall for the 09 96 CI that I'm aware of.
post #8 of 8 (permalink) Old 04-01-2014, 10:59 PM
:bikerguy:just had primary bearing replaced in my 05 heritage. Back in the saddle again, woo hooooo!
iameasy is offline
