Spark plugs not firing - Harley Davidson Forums: Harley Davidson Motorcycle Forum
post #1 of 6 (permalink) Old 06-17-2011, 05:29 PM Thread Starter
the spark plugs on my dyna are not firing- rode it in the morning and then in the afternoon (approx. 3 hours later) I went to move it and it would not crank- I have checked the circuit breaker and fuses and they are okay- battery is fully charged- but the plugs are getting no fire- did a lean sensor reset and this has not helped-
anyone got an idea what could be wrong or what I need to check next?
boglesby is offline
post #2 of 6 (permalink) Old 06-17-2011, 05:42 PM
What year?
JimmyG is offline
post #3 of 6 (permalink) Old 06-17-2011, 05:51 PM Thread Starter
sparks plug not firing
Dyna superglide 2001 TC
boglesby is offline
post #4 of 6 (permalink) Old 06-17-2011, 06:51 PM
If it's not cranking then that's your first troubleshooting step, how do you know the plugs aren't firing? You can't just hold the plug on the head and check for spark
JimmyG is offline
post #5 of 6 (permalink) Old 06-17-2011, 11:02 PM
EVO RULER
moose49's Avatar
Has it got a kicker? If not how do you know the plugs aren't firing it has turn over for them to fire!
*CONFORMITY IS JUST A SLOW FORM OF SUICIDE*
******SUPPORT YOUR LOCAL INVADERS*******
********RIP RUBBERDOWN RIDE FREE********
moose49 is offline
post #6 of 6 (permalink) Old 06-18-2011, 01:08 PM
Not only that but plugs have to be in te head to fire, ckp reads the slowing of the crank on the compression stroke knowing when to fire, you can hold the plugs against the head and check for spark, but you have to install a dummy plug in the spark plug hole as well
JimmyG is offline
