Anything will work, but what you have here just simply isn't worth what it would take. Best bet find 06 superglide wheels. Unfortunately everyones doing it so be prepared to pay. It will save you money and aggravation in the long run. If you get 08 and up wheels you will need to change the bearings and internal spacer. 06 and 07 are the same axle. Oh and you will need a rotor but that has to be from an 06 or 07, your bike uses 11.5 inch rotor and 08 is 25 mm. You can reuse you stock rear though.
