87 octane in a 2012 - Harley Davidson Forums: Harley Davidson Motorcycle Forum
Old 11-10-2012, 09:03 PM   #1 (permalink)
sleeves13's Avatar
87 octane in a 2012
as many of you know there's a little bit of a gas shortage here in n.y. ... i only run 93 oct in my 2012 dyna but thats even harder to come by. i have plenty of 87 oct stored in the garage , what do you guys think? am i going to notice a difference with the 87 , should i ad an octane booster? or will that screw up the injectors? any help will be appreciated
sleeves13 is offline   Reply With Quote
Old 11-10-2012, 09:10 PM   #2 (permalink)
MPG'S? Who gives a
Craiger's Avatar
Images: 8
It won't hurt anything, It might not perform as well. That's all.
Injectors won't know the difference. Hang in there you guys, I hope things start getting better soon.
08 FLHTC. Breathing well and getting lots to drink.
Craiger is offline   Reply With Quote
Old 11-10-2012, 09:39 PM   #3 (permalink)
A lot of the little towns I ride through don't even have 91 octane premium. I've had no issues filling up with 87 octane regular in my 2012 FLTRX.
About the only thing I've noticed is a tendency to "ping" when rolling on the throttle if my RPM is below 2K, and less miles per gallon. If pinging becomes an issue simply drop a gear.
The screaming eagle octane booster works nice if you go that route, but the cost is equal to another gallon of fuel and probably doesn't help the mileage enough to warrant.
Yes it runs better on 93 but you do what it takes to get you down the road.
Old 11-11-2012, 06:41 AM   #4 (permalink)
sleeves13's Avatar
Thanks guys !
Old 11-11-2012, 06:55 PM   #5 (permalink)
'11 SuperGlide FXDC
Wrgiacona's Avatar
How long has it been stored?
Wrgiacona is offline   Reply With Quote
Old 11-11-2012, 08:01 PM   #6 (permalink)
icy
Padawan
just for the fun of it: for the past week or so (ever since the gas shortage epidemic) the only gas we can find here in NYC is regular. Yeap. Regular. And every bike you see riding around the city is using regular gas. Including my Ozzy (Sportster Iron 2012) And every other rider I know - pick a make and a model and I tell you right away, it's been running on regular gas for the past week or so.
It runs just fine. No problems so far.
icy is offline   Reply With Quote
Old 11-12-2012, 07:19 AM   #7 (permalink)
03 CVO RK
GotGold's Avatar
This summer I had to gas up with regular on a road trip. I only ran the one tank but did not notice any difference in the bike. I stayed off the throttle, made sure I was in the 2500 rpm range and it was good to go. I wouldn't do it all the time but in a pinch it seemed to work.
"Our lady of blessed acceleration don't fail me now."--- Elwood
GotGold is offline   Reply With Quote
Old 11-12-2012, 08:15 AM   #8 (permalink)
sleeves13's Avatar
Gas in the garage was only a week old . I had about half a tank of 93 and topped it off with 87 . Ran fine all day and happened to pass a gas station out in long island with no lines and 93, so topped it off on my way home ! Alls good
Old 11-12-2012, 08:27 AM   #9 (permalink)
Millwright
petew's Avatar
I am running 87 octane in my '11 RG but I add my own octane booster, 4 gal of 87 unleaded with 1 gallon of 110 leaded racing fuel. My mileage is nearly 5 mpg better vs running the supreme 91-93 octane, 44mpg vs 39.2mpg. The price is a little more expensive, but no pinging, and the performance is even noticeably better. I was 2-1 regular vs racing, and now at 4-1 and that is where I will stay. After a couple of months I will run the numbers and refigure the averages...
Of course, this is of little help to the OP... I hope it is starting to loosen up a bit!!!!!!
103" w/Race Kit,Stage IV 117HP 111TQ
SE 259E Cams
SE Heavy Breather AC (Scott's modified)
SE Race Tuner
V&H Power Duals & Hi Outputs
SE CNC Heads 10.62/1 w/SE 58mm TB
John Scott port matching
Renegade Racine wheels. 21x3.5/ 17x6.25
http://www.harley-davidsonforums.com...845-petew.html
petew is offline   Reply With Quote
