Fender foam - Harley Davidson Forums: Harley Davidson Motorcycle Forum
Old 11-11-2012, 03:10 PM   #1 (permalink)
Captain Dave
Tramp55's Avatar
Fender foam
I have a 2012 wide Glide and will ride mostly with the stock seat without the brick on the rear fender. There are four square foam pads that sit on the fender for protection when using either the stock brick or a two up seat (that was required by the wife). Question is what happens if I remove these, will the two up seat rub on the fender? I am going to get the bra/fender cover when solo seat is on to cover the fender, but need to remove the foam pads. Looking for input.
Tramp55 is offline   Reply With Quote
Old 11-11-2012, 04:36 PM   #2 (permalink)
GlideWide's Avatar
Remove them with a hair dryer or something that can get the glue nice and hot and they will peel right off.
Next, when that glue is still hot, as soon as u get one off place them directly on the 2-up portion of the seat where they were when they were on the fender. Since they will be on the seat it will fix ur problem.
Jared
2012 FXDWG
GlideWide is online now   Reply With Quote
Old 11-11-2012, 04:46 PM   #3 (permalink)
squeekie's Avatar
When I removed my side reflectors from my forks, and my fuel tank emblem, I used a thin string and sawed back and forth as in dental flossing. Then used goo remover on the adhesive that remained.
Ward, don't you think you were a little rough on the Beaver last night?
2005 XL1200C Vance & Hines Staggered Short Stacks w/QQ Thunder Monster Baffles, D & M chrome spike air cleaner, 48, 185 jets, 12" Burly's, Mustang Cyclone solo seat, Progressive 412 shocks.
squeekie is offline   Reply With Quote
Old 11-11-2012, 06:37 PM   #4 (permalink)
Blasta's Avatar
Genius!
Sent from my DROID X2 using Motorcycle.com App
The hurrier I go the behinder I get!
Blasta is online now   Reply With Quote
Old 11-14-2012, 03:54 PM   #5 (permalink)
Captain Dave
Tramp55's Avatar
I took a hair dryer and heated up the foam. Worked perfectly. I glued them onto the two up seat before the glue cooled off. Thanks for the suggestion, see, this forum is valuable even for the common sense things we all don't think of.
Old 11-14-2012, 10:31 PM   #6 (permalink)
GlideWide's Avatar
Lol, those are the ones that will get ya everytime! Cool man, glad I could help
Jared
2012 FXDWG
