» Site Navigation |
» » » » Motorcycle Forums
» Our Partners |
12-04-2012, 07:05 PM
#11 (permalink)
I installed LED turn signal lights for my 2012 Wide Glide from Custom Dynamics, I was confused about the need for an load equalizer too. I gave Custom Dynamics a call to see what I really needed, that is when I found out about the CanBus system.
They work great.
12-10-2012, 04:03 PM
#12 (permalink)
What lights did you get from Custom Dynamics?
2012 FXDWG103
"What, me worry?" -Alfred E. Neuman
12-11-2012, 06:32 PM
#13 (permalink)
Originally Posted by Pappa P
H-D Bullet Style Turn Signal LED Inserts (DOT Approved)
Red 1157/dual intensity
Same for front except the amber version. They have a pigtail that plugs right into the blub socket.
12-12-2012, 09:35 AM
#14 (permalink)
The customdynamics lights work great. 2012 or newer, no load equalizer needed. i've got them all the way around.
12-12-2012, 08:17 PM
#15 (permalink)
Thanks guys.
2012 FXDWG103
12-16-2012, 09:58 AM
#16 (permalink)
I recently installed Kuryakyn led turn signals on my 2013 FXDC. No load equalizer needed.
03-04-2013, 05:19 AM
#17 (permalink)
Hi.
Anyboy knows, if a fix for the rapid flashing Dash indicators are available. ?
I tried to put in some 9Ohm resistors for each turn signals, but it dosn`t work.
03-04-2013, 07:49 AM
#18 (permalink)
I just ordered turn signal LED lights for my 2012 Dyna Wide Glide. I ordered the Oaracle 115718L3CR and te 115718L3CA for the front and rear. I also have the rear chopped fender LED brake light from HD. I have been through the forums and have found different opinions if I am going to need a load balancer. Has anyone had any experience with this?
Thanks,
Swapped out the 1157 standards for the replacement LED bulbs in my 2013 FLS. The lights work just fine without a load balancer. The indicator lights in the dash blink a little fast but the signals blink at normal rate. 12 & 13 Harleys have an electronic signal stat. Oh by the way LED's are bright as hell.
If it ain't red it ain't FAST!
03-04-2013, 08:29 PM
#19 (permalink)
I just ordered some K & S technologies LED black turn signals for the ends of my grips. Should be visible from front and back. I'll let you know how they work. Got them for $67 shipped. http://www.surfsidemoto.com/mm5/graphics/00000001/KAS20400453L.jpg[/IMG]
03-05-2013, 07:47 AM
#20 (permalink)
Bass Player
Just got an email from Badlands;
From: Dan from Badlands <dan@badlandsmotorcycleproducts.com>
To: mlpeled@sbcglobal.net; Sales@BadlandsMotorcycleProducts.com
Sent: Tuesday, November 20, 2012 1:20 PM
Subject: RE: Order Form
Hi Michael,
The 2012 Dynas use Harley's new CanBus BCM (Body Control Module) system. You
should be able to run this without a Load Equalizer. You might see rapid
flashing on the dash indicators, but the signals should flash normally. If
they do not, you will need to have the Harley dealer reset the BCM for LEDs.
Thanks,
Dan
This is exactly what happens on the '12 and '13 models with the CanBUS. The signals flash normally, the dash flashes rapidly (This is normally how the bike tells you that a bulb is out.)
You can correct the dash thing by installing this inline with your front signals.
Universal Inline Resistors 20500065 Ks Technologies 103570 2050-0065
If I wanted all the comforts of home, I would just stay there.
| Thread Tools |
| Display Modes |
Linear Mode
