Lowest seat? - Harley Davidson Forums: Harley Davidson Motorcycle Forum
Old 11-25-2012, 04:08 PM   #1 (permalink)
RicManSr's Avatar
Lowest seat?
Does anyone know of a seat that 1: is the lowest, and brings you the furthest toward for a Dyna super glide?
I'm 5'2" and could use it a bit lower and closer to the forward pegs.
2004 Dyna SuperGlide
Silver and shiny.
RicManSr is online now   Reply With Quote
Old 11-25-2012, 04:27 PM   #2 (permalink)
RicManSr's Avatar
Furthest forward. Sry for the typo.
Silver and shiny.
Old 11-26-2012, 01:52 PM   #3 (permalink)
Latinjubileo's Avatar
There is a Reach Seat from HD, I tried it when I first bought bike, not confy at all, try a used StreetBob solo seat, or 11" rear shocks will do trick.
2006 Dyna Super Glide Rinehart 2-2 Cross-Back Staggered, Extended rear fender, Handcrafted Solo Bag
Latinjubileo is offline   Reply With Quote
Old 11-26-2012, 08:15 PM   #4 (permalink)
TGPNW
93horse's Avatar
Find a custom seat builder / upholster in your local area and have them fit the seat to your size and needs.
93horse is online now   Reply With Quote
Old 12-17-2012, 05:46 PM   #5 (permalink)
If you can ride out to hollister, ca or Daytona, fl...visit Corbin seat, they will fit you and you can test ride the seat and with your new seat same day,
totowrench is online now   Reply With Quote
Old 12-29-2012, 09:07 PM   #6 (permalink)
redcad's Avatar
Not just the lowest; also look at the front of the saddle to see how narrow it is. Makes a big difference in touching the ground at stops.
A Vintage Wide Mustang on my FXDC is way wider for support, but very narrow up front.
At 5' 2", you will be way more comfortable with mids than forwards IMHO.
"There is no place like chrome"
redcad is offline   Reply With Quote
Old 12-29-2012, 09:16 PM   #7 (permalink)
FritzHD's Avatar
Danny Gray butt crack is what is on my wifes Dyna. She's your height and she can stop flat footed. Lowest I've found.
Sent from my SAMSUNG-SGH-I897 using Motorcycle.com Free App
FritzHD is online now   Reply With Quote
Old 12-29-2012, 09:35 PM   #8 (permalink)
Ride Hard
DSMITH's Avatar
Highly recommend lowering the bike as much as possible without compromising handling. That mean no lowering block. Then see how you fit the bike. After lowering the bike look for a lower seat (if still needed). I have a short inseam and have been down this road a few time. Your going to spend several hours in the saddle you need a good seat. Shave to much of the seat and your not going to enjoy those long rides. Look at a good pair of riding boots. If you loose a little in the suspension, a little in the seat, and wrap up with a good boot. Follow these rule and end up very happy.
You can't make up for shortness with one extreme modification.
DSMITH is online now   Reply With Quote
Old 12-30-2012, 05:42 PM   #9 (permalink)
redcad's Avatar
That is a tough one. These bikes throw sparks, especially to the right, pretty easy. Even if you are not an aggressive rider you may need whatever lean angle there is now in an emergency; lowering will reduce lean angle.
Try the seat first and then lower if you must. Act like you are buying a seat from them and perhaps your local H-D Dealer can help at their "Fit Shop". Worth a try.
Riding boots was a great suggestion; thicker sole and heel.
Old 12-31-2012, 12:07 PM   #10 (permalink)
'11 SuperGlide FXDC
Wrgiacona's Avatar
At 5'2" unless you are all legs I just don't see you being able to use the forward controls. I'm 5'8" with a 32" inseam and I certainly can't use the standard ones and can just barley use the reduced reach forward controls.
I'd seriously look at using the mids.
Wrgiacona is offline   Reply With Quote
