Low rider hard to start - Harley Davidson Forums: Harley Davidson Motorcycle Forum
post #1 of 15 (permalink) Old 01-03-2013, 08:50 PM Thread Starter
Hi, Im new to this forum. I did a search did not find any thing sounds like my prob. I have an 06 Low Rider had it about 2 years 17,000 miles. When I got it, it tiurn over about 2 times fire up just fine, lately its taking longer to start. turns over fine, just takes longer to start then runs good. thought mabe some of your experience might help me start, fuel filter, pump,? I changed the plugs about 6000 miles back, air filter is new. I do think its running rich. And it does have fuel injection. Thx
Rick06 is offline
post #2 of 15 (permalink) Old 01-03-2013, 09:29 PM
nipplesurfer's Avatar
Start with a little more info. Is it the original battery, and is it kept on a tender? Is it only the first start of the day, or is it all starts? My first guess would be battery going flat in the absence of better information.
It may be that the only purpose of your life is to serve as a warning to others
nipplesurfer is online now
post #3 of 15 (permalink) Old 01-03-2013, 09:48 PM
Go SEAHAWKS!!
StillBill's Avatar
Images: 25
"The difference between the impossible and the possible lies in a person's determination."
Tommy Lasorda
"It's easy to curb the freedoms of others when you see no immediate impact on your own."
Malcolm Forbes
"Give the gift of your absence to those who do not appreciate your presence."
2000 Wide Glide Stage II
StillBill is offline
post #4 of 15 (permalink) Old 01-03-2013, 10:40 PM Thread Starter
Battery is about 2 years, first start or when its cold is when i notice most, but stiil takes longer even when warm.
Rick06 is offline
post #5 of 15 (permalink) Old 01-03-2013, 10:42 PM Thread Starter
What do you mean tender
Rick06 is offline
post #6 of 15 (permalink) Old 01-04-2013, 12:31 AM
Go SEAHAWKS!!
StillBill's Avatar
Images: 25
There is a thread or two on here about Battery Tenders. You can find a lot on Google as well. Here is a link to one at a very reputable and well known supplier.
Battery Tender Junior Charger - Cruiser Motorcycle - Motorcycle Superstore
Tommy Lasorda
Malcolm Forbes
post #7 of 15 (permalink) Old 01-04-2013, 12:49 AM Thread Starter
this looks like a charger, I put a charger on it didnt seem to change any thing Ill try it again would this serve the same purpose, my charger does a tricle charge and stops when fully charged.
Rick06 is offline
post #8 of 15 (permalink) Old 01-04-2013, 12:25 PM
Pull the battery and bring it to get tested. The cold cranking amps are probably too low.
Gotwages is offline
post #9 of 15 (permalink) Old 01-04-2013, 02:39 PM
Also if the battery checks out ok check and change your leads, even if the ends look good its what you cannot see that may hide the problem.
They can corrode and lose there current carrying ability, hence why even a good battery wont do you any good. Check that your ground is nice, tight and clean.
JTR
03geetee is offline
post #10 of 15 (permalink) Old 01-04-2013, 08:32 PM Thread Starter
I will have the battery checked, but to help me understand, even if the engine seems to turns over OK it still could be the battery? This is why I didnt consider it before, it turns over ok, it just takes longer to start.I have noticed if I hit the starter for a few seconds, let off, then hit the starter again it starts right up. I hope yall are right, thats what sombody at work told me too, a battery and/or cables is easy. I want to try to get ahead of this before it becomes a real problem.
Rick06 is offline
