Lowering Fat Bob - Harley Davidson Forums: Harley Davidson Motorcycle Forum
post #1 of 23 (permalink) Old 04-20-2009, 06:40 PM Thread Starter
Thumbs up Lowering Fat Bob
Hi all -
Obviously a "newbie" here, but glad to find you!
I have an '08 Fat Bob and want to lower it. Thinking about raking out the front just a few degrees and lowering the rear....suggestions, thoughts, tips, directions and/or considerations of any type welcome!
Thanks in advance....
Chris
BreezyRider is offline
post #2 of 23 (permalink) Old 04-20-2009, 09:17 PM
when did it start 4u
Jacket4256's Avatar
for lowering there are blocks that relocate the shock back which is the cheaper way or you can do new shocks all together which is more expensive, but some say it is more comfy
2004 Sportster
2012 HD Road Glide Ultra
2006 GTO with idle problem
2011 Subaru OB (DD)
A great man once said
Jacket4256 is offline
post #3 of 23 (permalink) Old 04-21-2009, 05:10 AM
Burley makes a lowering kit that I've used for about $80, that uses your stock shocks, and lowers the bike 1.5".
Progressive makes the 412 shocks for about $180 or so, that are 1" shorter.
R.I.P. Rubberdown. 1971-2012
2005 E.G. Classic
S&S 510 cams
Baisley Oil pump spring
CYCO tensioners
V&H Fuelpak
SE 3.5" pipes
K&N filter
Fueling lifters
S&S adj pushrods
Swingarm stabilizer
Dave63 is offline
post #4 of 23 (permalink) Old 04-21-2009, 06:45 PM
JBONE's Avatar
Think White Bros, makes a kit for under $100? Can get a sleeker seat to, if you don't wanna mess w/ shocks, remember changes ride.
Pain is just weakness leaving the body!
Once you go Bagger, you don't come back
JBONE is offline
post #5 of 23 (permalink) Old 04-22-2009, 05:31 PM Thread Starter
Thanks all - I'll look into it all. Anyone have experience with raking out the front? I'm thinking about 6 degrees..........
I've gone the seat route before - looked great, but my lower back suffered greatly!
Chris
post #6 of 23 (permalink) Old 04-22-2009, 05:46 PM
JBONE's Avatar
Chris
can't be done unless you cut/weld neck @ this point which i would not EVER even consider!! I already checked EVERYWHERE for tree's w/ rake. Accutronics made a nice rake for my fatboy...if you find anything I missed-let me know!!!!
JBONE is offline
post #7 of 23 (permalink) Old 04-22-2009, 05:49 PM Thread Starter
thanks JB - I'll let you know if I find anything.....
post #8 of 23 (permalink) Old 04-24-2009, 04:24 PM Thread Starter
triple trees for Bob
JB -
guess what i found? triple trees for 49mm fork tubes - comes in 3, 4 & 7 degrees.... check out a place called cass county choppers.
they are actually on ebay - in ebay motors, search item #400014431416. it's the 7 degree trees, but the other info is there as well.
cheers!
post #9 of 23 (permalink) Old 04-24-2009, 06:24 PM
JBONE's Avatar
JB -
cheers!
Nice, I'll check it out!! I looked everywhere, but ebay:
JBONE is offline
post #10 of 23 (permalink) Old 04-25-2009, 05:21 AM
JBONE's Avatar
BR, Im gunna contact seller, gotta find out if I will need new tubes?...If all sounds good & everything will work, I'll grab em, have them powdercoated black:mwink...Now if i can only find smooth struts? checked everywhere...hint-hint:mwink:lol8
JBONE is offline
