EXHAUST SYSTEM #65842-00A or #65842-07 - Harley Davidson Forums: Harley Davidson Motorcycle Forum
post #1 of 9 (permalink) Old 06-19-2011, 09:32 AM Thread Starter
HugoBetz's Avatar
Will a HARLEY EXHAUST SYSTEM #65842-07 for a FLSTC, this part number is for model years 07 - 11, fit on a 1996 FLSTC with the Evo motor?
What about EXHAUST SYSTEM #65842-00A, which is for model years '00-'06?
I've seen a few after market systems that will fit '94-'06 softails is this true for OEM system?
Hugo
2000 FXST-98"-Dan Vance Heads-37G cam-S&S gear drive-Mikuni 42mm-Dynatek Ignition module-Python 2x2
2007 Electra Glide Ultra Classic
Two tours in Afghanistan
Army Corp of Engineers
HugoBetz is offline
post #2 of 9 (permalink) Old 06-19-2011, 01:27 PM
The big difference is any 07-11 exhaust system has O2 sensor bungs that needs to be plugged.
Out side of that, the head spacing is the same. You may have to modify a mounting point, but it should bolt up.
R.I.P. Rubberdown. 1971-2012
2005 E.G. Classic
S&S 510 cams
Baisley Oil pump spring
CYCO tensioners
V&H Fuelpak
SE 3.5" pipes
K&N filter
Fueling lifters
S&S adj pushrods
Swingarm stabilizer
Dave63 is offline
post #3 of 9 (permalink) Old 06-19-2011, 03:08 PM Thread Starter
HugoBetz's Avatar
Thanks for the input Dave63!
Hugo
HugoBetz is offline
post #4 of 9 (permalink) Old 07-06-2014, 04:02 PM
exhaust
So ur sayin a screamin eagle exhaust off of a 05 heritage will work on a 96 heritage?
HarleyMan2010 is offline
post #5 of 9 (permalink) Old 07-06-2014, 04:10 PM
SE mufflers have nothing to do with the head pipe. Mufflers are the same as well.
. Softail didn't get O2 sensors till 2007. Even so, you can plug the sensor ports on headers off newer models and use them on older models.
2005 E.G. Classic
S&S 510 cams
CYCO tensioners
V&H Fuelpak
SE 3.5" pipes
K&N filter
Fueling lifters
S&S adj pushrods
Swingarm stabilizer
Dave63 is offline
post #6 of 9 (permalink) Old 07-06-2014, 04:18 PM
exhaust
Well i would have to use the whole system with this setup as my factory pipes are staggered and the se setup both mufflers are at the rear..dont think the se setup has bungs for o2s....
post #7 of 9 (permalink) Old 07-06-2014, 04:28 PM
05 and 96 are interchangeable as long as mounts are identical at right lower frame.
2005 E.G. Classic
S&S 510 cams
CYCO tensioners
V&H Fuelpak
SE 3.5" pipes
K&N filter
Fueling lifters
S&S adj pushrods
Swingarm stabilizer
Dave63 is offline
post #8 of 9 (permalink) Old 07-06-2014, 04:34 PM
exhaust
Great thx! So head mounts are same on evo and twin cam?
post #9 of 9 (permalink) Old 07-06-2014, 06:19 PM
FritzHD's Avatar
Yes
FritzHD is online now
