removing baffles - Harley Davidson Forums: Harley Davidson Motorcycle Forum
Old 11-13-2012, 07:31 AM   #1 (permalink)
Marknett's Avatar
removing baffles
My 2012 switcnback ,I had a twin slash slip-on installed at dealer .. I'm trying to remove baffle . I got the screws out but can't get the baffle to move .. any ideas?
Life's a circle ...
You are just the bullseye in the center
Marknett is offline   Reply With Quote
Old 11-13-2012, 08:14 AM   #2 (permalink)
SCHMIDTYS's Avatar
Hit it out from the front end. Use something like a broomstick handle and a BFH. The engine isn't going to run very well with no baffles in the muffs tho !
Old 11-13-2012, 08:15 AM   #3 (permalink)
SCHMIDTYS's Avatar
Another thing. If those are bolt on end caps you removed the bolts from the baffles might be welded into the muffs. What brand muffs ?
Old 11-13-2012, 08:17 AM   #4 (permalink)
Marknett's Avatar
factory header 2-into-1 with factory cat convertor and vance and hine twin slash slip-on .. stage 1 upgrade and download
Life's a circle ...
Old 11-13-2012, 06:22 PM   #5 (permalink)
Marknett, The problem never is whether or not you talk to yourself, it's not even a problem when you answer. The problem arises when you ask yourself a question then go HUH?
Old 11-13-2012, 11:22 PM   #6 (permalink)
Marknett's Avatar
Sometimes I'll get so aggravated at the wife , I go for a walk and still be having the argument by myself . She will be answering me in my head and I will just be going off out loud .. lol
Life's a circle ...
