Potential Exhaust Issue - Harley Davidson Forums: Harley Davidson Motorcycle Forum
Old 11-21-2012, 08:00 PM   #1 (permalink)
Good evening all. I have a 2009 Sportster 1200L and I bought it used a few months back. I have recently put on forward controls and the manual called for the removal of the exhaust.. i could remove it because the bolts on the cylinder where the exhaust connected were so rusted that i couldnt move them. I was able to get the pipe out of the way just enough to change the controls but now i have this extra vibration feel when I ride. It has sound like its a faster revving sound and a faster vibration than normal.
Anyone have any clue on what i had done? I though perhaps i losened the exhaust from the cylinder but i dont have a way of getting them off.
Thanks in advance
Wrickter is offline   Reply With Quote
Old 11-21-2012, 11:23 PM   #2 (permalink)
GlideWide's Avatar
I say go back through the entire process exactly as u did it. Make sure all bolts are secure and nothing was bent or is not sitt flush. Also, if it is rusted around the connection. I would recommend going to auto part store they have so many different products to get bolts off that are rusty. If u do that make sure to get a new gasket to replace on the exhaust from HD shop.
This is what I would do but just my .02. Best of luck
Jared
2012 FXDWG
GlideWide is offline   Reply With Quote
Old 11-23-2012, 07:08 AM   #3 (permalink)
Is the exhaust touching your controls? If so it will transmit vibration, potentially through the whole bike.
chris_lacey is offline   Reply With Quote
Old 11-23-2012, 09:43 AM   #4 (permalink)
Get youself an impact driver. They're great for loosening frozen fasteners using a hammer .
RAD_Softail is offline   Reply With Quote
Old 11-23-2012, 09:51 AM   #5 (permalink)
mjkrause711's Avatar
You might want to also check the exhaust brackets and make sure one of them isn't broken. If one of those is broken or loose they can cause a lot of extra vibration.
mjkrause711 is offline   Reply With Quote
Old 11-26-2012, 07:52 PM   #6 (permalink)
Yeah the front exhaust is touching the controls... that could be it.
