Help Backfire issue - Page 2 - Harley Davidson Forums: Harley Davidson Motorcycle Forum
Old 12-06-2012, 07:35 PM   #11 (permalink)
98DARKHORSE's Avatar
depending on the size of the hole, velocity may or may not be an issue, but rather the motor running leaner now would be my concern
98 Evo 83.5ci, custom cam, 44cv, lightened ballanced crank, H-Beam rods, beehive springs, tapered pushrods, johnson hylift lifters, SE slip-ons no baffle, 101.78 hp @ 6200rpm
98DARKHORSE is offline   Reply With Quote
Old 12-09-2012, 11:34 PM   #12 (permalink)
sorry for slow response to all the questions... I will try to get them all answered.. I just have the stock mufflers with the baffles taken out.. They were done by a local professional machine shop here locally... I do not have the original baffles. However, I do still have the stock exhaust... Haven't noticed anything performance wise as of this point.. Was considering getting a new exhaust just haven't found one sound that I like so far...
StreetGlide846 is offline   Reply With Quote
Old 12-10-2012, 09:32 AM   #13 (permalink)
if you are running free flowing mufflers your ecm is seeing this as a lean condition due to fresh air entering you mufflers aka reversation so you need to lean it out a little some and you decel. popping will go away.this is very true if you are running a decatted head pipe.
hardheaded is offline   Reply With Quote
Old 01-01-2013, 09:50 PM   #14 (permalink)
Time2puckup's Avatar
Buy a pc5 and have it tuned. Not all the deceleration pop will disappear but most of it will. Also you will enjoy the increase in power and will not hurt the engine by running it lean.
Time2puckup is offline   Reply With Quote
