Old 09-18-2009, 05:09 PM   #1 (permalink)
S&S Super Rich snag?
Hey all,
Need to pick some brains cuz mine is hurting. I am just finishing putting a stock 1986 evo into my ride. Its a 4 spd swing arm that used to house an 88 ci shovelhead that met an early demise.
I'm using the Dyna S that i salvaged from the shovel, LAF pipes i bought for it and the S&S super E that came out of the shovel.
I've taken the carb apart, cleaned it and reinstalled it. The idle mixture and speed has been set IAW the factory manual as has the accelerator pump setting.
The bike starts and idles fine, when i try to run it up from idle it runs like crap, pops, backfires and spits fuel out the carb and i get loads of black smoke from the rear exhaust I double checked timing, and took the .295 int jet out of the carb and put in a .28.
I'm thinking i'm still rich with the .28 but that doesn't seem logical for a 1340 ci motor.
Thoughts?
jb88ci is offline   Reply With Quote
Old 09-18-2009, 06:56 PM   #2 (permalink)
Ride it!
dale0812's Avatar
You should be able to go to S&S Cycle - Performance Parts for American V-Twins and get all the information for you application, a 28 jet does sound that far off IF I remember right, you can also get the directions for setting that carb. up there.
dale0812 is offline   Reply With Quote
Old 09-19-2009, 07:22 AM   #3 (permalink)
nitro freak
prodrag1320's Avatar
Images: 5
theres a small,blue o ring that goes on the accelerator nozzle coming up from the bowl that goes thru to the carb throat,make sure its on there or the nozzle will act like another jet,and give the exact prob you have
kirby
vee twin racing
prodrag1320 is offline   Reply With Quote
Old 09-19-2009, 07:52 AM   #4 (permalink)
senior citizen
SCHMIDTYS's Avatar
kirby
vee twin racing
Yes exactly ... that BLUE oring . Also turn off the fuel petcock when running the engine and if the problem clears up as the bowl empties then the float is probably hanging up .
Old 09-26-2009, 03:05 AM   #5 (permalink)
Appalachian American
XDixiecratX's Avatar
And after all this good advice will you pay us a visit in the New to the community Page and introduce yourself.
THE HERD # 0001
XDixiecratX is online now   Reply With Quote
Old 09-27-2009, 08:16 PM   #6 (permalink)
Resident Choppaphile
ARBY's Avatar
Images: 10
Must have had a hell of a time getting that Evo in a Shovel frame.
ARBY
http://chopperville1.tripod.com
"The greatest crime of all is a wasted life."
ARBY is offline   Reply With Quote
vB code is On
