Vacuum fuel shut off valve leaks - Harley Davidson Forums: Harley Davidson Motorcycle Forum
post #1 of 3 (permalink) Old 04-04-2011, 08:52 PM Thread Starter
I have 2004 sporty 1200 with the vacuum fuel shut-off valve. just after riding a little, when I kill the engine, my fuel valve begins to leak. I think it only drips for a short time and stops. a tech at the local Harley shop told me that it is typical of the vacuum type valves to drip, and I just need to turn it off after riding. If i do this, it doesn't leak, but it's somewhat of a drag.
Has anyone else experienced this issue?
Sporty_Matt is offline
post #2 of 3 (permalink) Old 04-05-2011, 04:22 AM
Viet Nam 69/70
harvey13118's Avatar
Being an 04 the "O" rings may have dried up some. I do not think you can rebuild. They should not leak anyway shape or form.
My Heritage 05 had some corrision in it so I've been there, trying to rebuild. Working on carb could not shut fuel off in any position.
Get a new valve.
Life: VFW, NRA, NYSRPA(NYS Rifle Pistol Association)
2 favorite signs
CAUTION we do not dial 911 first.
DANGER if you are reading this U R in range.
05 FLSTC, 08 FLHTCUSE3
C4 IRONBALLS
2016 Ironbutt 1226 miles 19.5 hours
harvey13118 is online now
post #3 of 3 (permalink) Old 04-05-2011, 05:15 AM
Get a new valve.
The part that tears is a 3 hole'd molded rubber gasket. Rebuild kits available from HD.
Drag specialties sells them too.
Drag Specialties PETCOCK REBUILD KIT from Stormy Hill Harley-Davidson
R.I.P. Rubberdown. 1971-2012
2005 E.G. Classic
S&S 510 cams
Baisley Oil pump spring
CYCO tensioners
V&H Fuelpak
SE 3.5" pipes
K&N filter
Fueling lifters
S&S adj pushrods
Swingarm stabilizer
Dave63 is offline
