cv carb specs - Harley Davidson Forums: Harley Davidson Motorcycle Forum
post #1 of 9 (permalink) Old 05-10-2012, 10:22 PM Thread Starter
evorider1961's Avatar
cv carb specs
Anyone know the stock length of a cv carb spring and the hole that is sometimes drilled out larger in the slide?
evorider1961 is offline
post #2 of 9 (permalink) Old 05-11-2012, 12:52 AM
Badinfluence's Avatar
Read the sticky DAVE63 has posted above on carb rebuilding. you can also use the search. Hole is commonly drilled out to 1/8 inch, don't know what size it is to start. Length of spring will vary, age will tend to take some bounce out and change the unsprung length.
Badinfluence is offline
post #3 of 9 (permalink) Old 05-11-2012, 06:36 AM
Stock spring is 5.5" long, with 12.5 onces for 3" of compression.
Dynojet spring is 5" long with 8.8 onces for 3" of spring compression.
R.I.P. Rubberdown. 1971-2012
2005 E.G. Classic
S&S 510 cams
Baisley Oil pump spring
CYCO tensioners
V&H Fuelpak
SE 3.5" pipes
K&N filter
Fueling lifters
S&S adj pushrods
Swingarm stabilizer
Dave63 is offline
post #4 of 9 (permalink) Old 05-11-2012, 11:06 AM Thread Starter
Thanks for the info. Any idea if a medium spring will effect mpg compared to a stock spring?
post #5 of 9 (permalink) Old 05-11-2012, 02:23 PM
The spring determines the effort and time it takes to lift the slide, in conjunction with the airbleed hole in the slide. If the slide rises faster, the vehicle gets more fuel, via the main needle lifting....
Lighter spring = more fuel = less fuel mileage.
2005 E.G. Classic
S&S 510 cams
CYCO tensioners
V&H Fuelpak
SE 3.5" pipes
K&N filter
Fueling lifters
S&S adj pushrods
Swingarm stabilizer
Dave63 is offline
post #6 of 9 (permalink) Old 05-11-2012, 02:51 PM Thread Starter
Perfect, I kinda figured that. Something to think about.
post #7 of 9 (permalink) Old 05-11-2012, 03:25 PM
I lay awake at night, thinking of the stupidest things.......
2005 E.G. Classic
S&S 510 cams
CYCO tensioners
V&H Fuelpak
SE 3.5" pipes
K&N filter
Fueling lifters
S&S adj pushrods
Swingarm stabilizer
Dave63 is offline
post #8 of 9 (permalink) Old 05-11-2012, 06:53 PM
Seeking knowledge is not stupid, ignoring your concerns is.
I did the same thing when I was building my bike in my mind. Cam choice, carb mods, exhaust and pipes kept me up all night. I'm very pleased with the way my bike performs. You are doing the right thing by asking!
I settled for info partly from Larry hardy performance heads and Steve Mullen from night rider. I choose to use the spring from the SE 44 mm carb. 27728-99 the info is from Steve Mullen on night rider. My cam, crane h-286-2b advanced, thanks to Larry hardy. My exhaust, Larry, cycle shack muffler pipes.
I can't close and go to www.nightrider.com to the v-twin tech site with out loosing this post, but the spring specs to the stock is listed. Some take two coils from the stock.
As noted there is a great post on the cv with pictures on this forum that you should read.
Sent from my iPod touch using MO Free
Softail99fb is offline
post #9 of 9 (permalink) Old 05-11-2012, 09:20 PM Thread Starter
Yep I hear you
