fuel line routing on 77 FLH,, - Harley Davidson Forums: Harley Davidson Motorcycle Forum
Old 12-09-2012, 12:03 AM   #1 (permalink)
mine comes out of the petcock strait down and bends in thru/between the jugs near the bottom and then bends back up to the bottom of the carb. I dun like the heat it may be getting, even thou it's got a cover over it,,,, is there a better way to run it? maybe up higher or around the back of both jugs? u got pics of yours ??? thanks
grouser is offline   Reply With Quote
Old 12-09-2012, 12:09 AM   #2 (permalink)
Harley Rider's Avatar
Sounds like the same way mine is routed and it's never caused a problem. I even still have the original rubber hose and it looks fine after years of riding in the southwest deserts and Mexico before moving up north.
1987 Softail Custom, stock except for added chrome, and still running like new after 100,000 miles.
Harley Rider is offline   Reply With Quote
Old 12-09-2012, 05:31 AM   #3 (permalink)
Greasy Member
Most if not all of HD's lines are like that. The reason was, oroginally, the petcock was on the right side. If something happened, fuel ran out uncontrolled, all over the hot engine and exhaust. With it on the left, it's only going to go on the ground.
You can cover it with the couregated black automotive covering like HD does, or replace it with a braided line. Either way, it's ok where it is.
Football Season is over....
Praise the Lowered!
11 year A.M.A. member.
4 year PA ABATE member.
Old 12-09-2012, 09:22 AM   #4 (permalink)
thanks gents,,,,, I do have a plastic wire loom cover on it,,,,, but am gonna make it at least double walled for my peace of mind,,,,, thanks for the help !!!
Old 12-11-2012, 09:18 PM   #5 (permalink)
tussuck's Avatar
I run mine the same route as the original poster BUT I run the hose through a piece of water hose, like radiator hose, that seems to shield it from the worst of the heat.
I prefer my engine blown not stroked!
D.L.R.A #1174
tussuck is offline   Reply With Quote
Old 12-12-2012, 08:58 AM   #6 (permalink)
yes that and a wrap of wire loom cover to make layers is a good idea,,,, thanks
Old 12-12-2012, 01:10 PM   #7 (permalink)
Luke 22:36
Kainam's Avatar
Images: 136
My FXR had a fuel line support that the fuel line ran through to keep it off of the cylinder fins.
Part number 45092-66, used from '66 - '89 on most models.
There's drones in my livingroom!
'05 Carbed Night Train
111 rwhp, 112 rwtq
Best 1/4 ET 12.557s
Best 1/4 MPH 108.59
Kainam is online now   Reply With Quote
Old 12-12-2012, 03:33 PM   #8 (permalink)
this is the way it needs to be done and you'll never have any problems with it
hardheaded is offline   Reply With Quote
Old 12-12-2012, 10:26 PM   #9 (permalink)
thanks for the great ideas,,,,, I was a little worried about it being s close to both cyl the way it was hanging down where the two jugs are the closest,,,, but ,,,, now that I think about it more heat rises and even thou the jugs are further apart at the top, it may even be hotter there,,,
