CV Carb jet needles. - Harley Davidson Forums: Harley Davidson Motorcycle Forum
post #1 of 1 (permalink) Old 04-24-2009, 01:49 AM Thread Starter
OK.....it's 0235am and I'm bored and can't sleep....lucky you!!
Here's some more info:
Here's a needle jet, dismantled from a carb. (a spare....not off my bike. I'm not THAT bored.)
You can see the carb top, diaphram spring, disphram with slide, plastic spring seat and the actual needle. This one is a Dynojet needle. It's adjustable. It also has a fat taper (#D147) and is a rich needle.
I also laid out 2 more needles, including a narrower taper Dynojet needle, and a stock needle, N72V, which is a nother rich running needle. Note the tiny washers next to it used to shim it with. THAT'S what you need to get for yours, unless you replace the needle.
Here's a chart to show you the various needles, widths and ranges of rich/lean.
R.I.P. Rubberdown. 1971-2012
2005 E.G. Classic
S&S 510 cams
Baisley Oil pump spring
CYCO tensioners
V&H Fuelpak
SE 3.5" pipes
K&N filter
Fueling lifters
S&S adj pushrods
Swingarm stabilizer
Dave63 is offline
