Old 05-02-2009, 08:54 PM   #1 (permalink)
Kelsbad
Talking Chick needs carb help
Just so you all don't think you're dealin with a guy thats a complete idiot. I'm a girl workin on my own bike. I have a 1985 lowrider w/ a 388 SS carb. Can you give me a few reasons why it's popping and backfiring, more so when I have choke on. It is firing and almost starts. Every 3rd or 4th try it catches fire and remains in the air cleaner cover for several seconds. I've leaned it out as much as poss. Carb was rebuilt less than a year ago and was running great.
Kelsbad is offline   Reply With Quote
Old 05-02-2009, 09:11 PM   #2 (permalink)
Darien1965's Avatar
Still sounds like its loading up, float may be sticking?????? Somthing that just started????You try it without the choke????? Gas doesn't come out the carb does it???
Darien1965 is offline   Reply With Quote
Old 05-04-2009, 04:47 AM   #3 (permalink)
COB
GAZOO!'s Avatar
Images: 86
Need more info. Did this just start happening? If so, what, if anything, happened directly before this? Could be a gummed up bowl, timing issue, many other things.
Search and ye shall find......the anwer to your exhaust question is in the exhaust forum.....whodda thunk it?
GAZOO! is offline   Reply With Quote
Old 05-04-2009, 07:54 AM   #4 (permalink)
CHOPPA RIDN MADNESS
Badassbrutus's Avatar
I hate theses first post no intro or pics help me now threads..
Except riding my Sled.
Old 05-06-2009, 12:05 AM   #5 (permalink)
Kelsbad
Sorry, been out of range a few days.
Bike has sat longer than I've ever let it sit before (4 mos). I did drain the fuel and clean the carb before trying to start it. And yes to you DARIEN1965, gas does dribble out of carb after cranking 2 or 3 times. (which, I assume, is why it's catching fire) The carb was rebuilt less than a year ago and I cleaned it the other day. If the float is sticking, should I just rebuild it again? Thanks for responding. I WANNA RIDE!!
Old 05-06-2009, 01:10 AM   #6 (permalink)
Old Member
Hawkmann's Avatar
Images: 7
Sounds like trash in fuel line holding float open.
Hawkmann is offline   Reply With Quote
Old 05-06-2009, 05:03 AM   #7 (permalink)
Ozbiker69's Avatar
Images: 5
I would recommend checking the Fuel filter and also clean the carb jets and stuff again. As it has been said here before, it does sound as if something is sticking. More power to you as a Chick working on her own ride. Go for it atleast you are having a go. I know heaps of males over here in Oz that would never work on there own bikes.
Patriots Australia
Queensland Chapter #973
Animal aka Rat Fink
Grow Old Disgracefully
Live to Ride : Ride to Live
F.T.W. & H.T.F.U.
Such is Life
"The Herd # 69"
Ozbiker69 is offline   Reply With Quote
Old 05-06-2009, 08:43 AM   #8 (permalink)
CHOPPA RIDN MADNESS
4months is long enough for gas to turn to varnish and gum up your carb take it apart clean it clean the tank and change the fuel filter always treat your gas for storage even if you drain the carb.
Old 05-06-2009, 12:16 PM   #9 (permalink)
Darien1965's Avatar
BTW what did you clean it with?, was it discolored inside?, did you try it without the choke??? Without starting it leave the gas on for awhile and see if gas still comes out the carb.
D
Old 05-06-2009, 05:10 PM   #10 (permalink)
The Northern Redneck
Blackdog 15's Avatar
stuck float ??? or timing off...
You can Sleep when ur Dead...
Baggers RULE !!!
HERD Member # 000015
vB code is On
