» Site Navigation |
» » » » Motorcycle Forums
» Links |
05-28-2009, 09:49 PM
#1 (permalink)
s&s shorty e
Well first and foremost i like to introduce myself to the forum. Im from Pittsburgh Pennsylvania and i recently picked up a 1977 Harley Davidson Sportster to work on for somebody. This bike is really really clean, new paint, new chrome, rigid frame, etc. Well it has a shorty e s&s carb on it. The bike sat with gas in it for a year and it gummed up the carb. Well i cleaned the carb 4 times now taking out every needle etc, replacing the accelerator pump rebuild and everything and everytime i install the carb back on the bike, it either back fires thru the exhaust with a flame and it only runs on choke for a small second or two. Each plug gets a clean blue spark. One thing i noticed however is the front pipe gets warm the the rear pipe stays cold. I can provide more info on this bike if needed.
thanks!
alex
05-28-2009, 09:53 PM
#2 (permalink)
CHOPPA RIDN MADNESS
You got a good intake seal and check your pipes make sure nothing crawled up them seeing it sat for a year.
Except riding my Sled.
05-28-2009, 10:30 PM
#3 (permalink)
Nothing crawled up the pipes because they are new to my understanding but ill check for sure. The intake seal however shows a bit of the carb when its in the right side of the heads when its in the rubber insulator. Perhaps its not tight enough.. Any other suggestions i can try before i go out there?
thanks for your suggestions to brutus.
05-29-2009, 07:45 AM
#4 (permalink)
CHOPPA RIDN MADNESS
Yep the rear is not firing ,you say it has spark,What color are the plugs,Might be fouled from trying to start and make sure you have a charged battery..Intkae leak is a big deal I would check that and the plugs then try to fire it up.If you cranked the air mixture screw down to tight on those carbs it puts a hole in the carb body and ruins it.Just a word of caution.
05-29-2009, 05:26 PM
#5 (permalink)
What im going to do is what you said and set the s&s to the factory settings and work from there. The plug however has a bright blue spark like the front plug does so can i assume its in good working shape?
05-29-2009, 07:12 PM
#6 (permalink)
I set the carb to the s&s factory settings and now it runs until you give it gas... What should i do now? I will honestly mail a person a 5.00 check to get a beer to the person that helps me get this running because quit honest, ive been losing sleep over this bike for 2 weeks now!!!
05-29-2009, 10:01 PM
#7 (permalink)
CHOPPA RIDN MADNESS
did you set you accelerater pump screw back to the factory setting then go form there it also might have to big a main jet in it doyou know the size of it?
05-30-2009, 12:04 AM
#8 (permalink)
ΜΟλΩΝ λΑβέ
Close off the accelerator pump when you get it started until you get your jetting right.
Start with idle mixture 1 turn out
.028 Intermediate
.066 Main
http://www.sscycle.com/admin/uploads...ns/51-1012.pdf
Originally Posted by Representative Suzanna Gratia Hupp
"How a politician stands on the Second Amendment tells you how he or she views you as an individual... as a trustworthy and productive citizen, or as part of an unruly crowd that needs to be lorded over, controlled, supervised, and taken care of."
Originally Posted by Thomas Jefferson
"Tyranny is defined as that which is legal for the government but illegal for the citizenry."
'05 Carbed Night Train
111 rwhp, 112 rwtq
05-30-2009, 09:01 AM
#9 (permalink)
CHOPPA RIDN MADNESS
WERD!! I was gonna scan my instruction sheets and put em up but you saved the day man....
05-30-2009, 07:29 PM
#10 (permalink)
I got it running guys, thanks a million! Now im just fine tuning it
| Thread Tools |
| Display Modes |
Linear Mode
