Old 06-05-2009, 02:58 AM   #1 (permalink)
Ride til ya rot!
fatboydoc04's Avatar
ThunderMax/AutoTune Advice & Info
I've been running a PCIII on my 04 EFI Fatboy for the last couple of years. I've never been really satisfied with the results it has given me and I am ready for a change. Been reading a lot on this and the other forums lately about the TM with AT. Am I understanding correctly that with TM and AT I will not have to do anything but install it correctly, start my little dumplin and let it adjust to the optimum tune. No downloding maps or tweeking at all? I can loose the PCIII and all my headaches will go away? The bottom has dropped out of my MPG since I cannot get anything in AR but E10 fuel. Im hoping the TM/AT will help me with this also. I would appreciate any input from anyone out there with knowledge and experience concerning this issue. Thanks in advance...fatboydoc
DEAL WITH IT!
fatboydoc04 is offline   Reply With Quote
Old 06-05-2009, 07:49 AM   #2 (permalink)
Eleft36's Avatar
Doc04,
I have Tmax, after spending hours trying with add on fuel delivery changers unsuccessfully.
It is not as simple as you say in your inquiry.
Tmax has starter maps for differently equipped bikes.
I have stock bike and started with Zippers recommended map which I slowly reconfigured to suit my style of riding.
I added timing in places and reduced fuel in places from the original map.
This is the beauty part of the Tmax, you can make changes and save as a new map and retain your previous map.
If you don’t like the new changes, just write the previous map back to the ECM.
If you are close, auto tune will tweak afr's (fuel air ratio) +/- in a few riding sessions.
Timing changes are manually done on the map pages very simply with the computer arrow keys and copy and paste feature.
I know now I could have saved money and time going with Tmax first.
Al
V&H Slip Ons W/Double quiet baffles
Stock A/C Stock Heads Stock Cams
Mustang wide Touring Seat Stock Bars H.D. Oil Cooler
Fat Boy Bags H-D Windshield Thunder Max A/T
SE Compensator Kit
Eleft36 is offline   Reply With Quote
Old 06-05-2009, 08:46 AM   #3 (permalink)
The Northern Redneck
Blackdog 15's Avatar
According to Matt Sanna from Mobile Cycle Service in Corona, CA, The Thundermax is a closed loop, wideband system. You will need a sensor bunge installed in each of your exhaust downpipes or use a late model exhaust system with them installed. I plan on putting a Thundermax on my scoot later this summer and will heliarc weld a bunge in where it is not visible and then just plug it in. Also Matt told me that there are basic Maps installed and the system self checks itself constantly..
mobilecycleservice.com if you want more info from Matt
You can Sleep when ur Dead...
Baggers RULE !!!
HERD Member # 000015
Old 06-05-2009, 11:43 AM   #4 (permalink)
Eleft36's Avatar
This "Matt Sanna" info is posted on zippers site.
I Thought the info wanted is from experienced users, sorry.
Al
SE Compensator Kit
Old 06-05-2009, 12:44 PM   #5 (permalink)
Ride til ya rot!
Originally Posted by Eleft36 View Post
Doc04,
Al
Hey Al, Thanx a bunch for your information. This clears a few things up for me. I plan on changing over to TMax soon. Guess I was thinking it was just a little too simple. Still sounds like the best and easiest way to go. thanx agian....ride safe brother.....Doc
DEAL WITH IT!
Old 06-05-2009, 12:47 PM   #6 (permalink)
Ride til ya rot!
Thanx man. I will go back to zippers and read all their info. Glad to know you guys are TMax fans. Makes me feel better about going with it. Ride safe.....Doc
DEAL WITH IT!
vB code is On
