idle screw is located on the right upper side of the cv carb.
it can be adj. with a small phillips screw driver without taking the air box off.
the pop at idle would signal a lean idle condition.
the idle/fuel adj. is located behind the cv carb bottom/center and requires that you drill out the small brass plug thats pressed into the adj. hole.
you will have to remove the air box and rotate the carb in order to do this.
when you drill. take note not to drill to deep! if you do, you'll hit the adj. screw, and damage the seat in the carb.
g
Rest in Peace my Brothers
