Sounds like a venting problem, usually in the cap...if it sputters when you're riding, reach up and loosen the cap, then retighten it...see if it stops the sputter....the early softail had this problem....by opening it, you are releasing the built up vacuum inside letting the fuel flow ...
You can Sleep when ur Dead...
Baggers RULE !!!
HERD Member # 000015
Reason: finish
