» Site Navigation |
» » » » Motorcycle Forums
» Links |
07-26-2009, 10:40 PM
#1 (permalink)
Help, Motor dieing while riding
86 FXR S&S Carb
very low miles and it had set up,I replaced the dirty air filter 3 weeks ago the 1st time it die'ed and put some seafoam in the tank no problems,several hunfred miles later it die'ed today running 45 mph.Pulled off the road and started [poorly] back up.never missed a lick for the 1 mile ride to the house.
bike normaly accelerates good but I have noticed lately that sometimes it seems to have a little pause when bumping up the speed a bit
should I start with the fuel filter?
I'm an explosives technician,if you see me running you might want to keep up.
Herd member #14
07-27-2009, 03:29 AM
#2 (permalink)
COB
Petcock or fuel filter? Maybe take your fuel line off and watch it drain into a tank and see if it is a fuel starvation problem.
I love them old FXR's. Great bike.
Search and ye shall find......the anwer to your exhaust question is in the exhaust forum.....whodda thunk it?
07-27-2009, 07:12 AM
#3 (permalink)
senior citizen
You might have a bubble of water in the S&S float bowl and it won't go away by itself . Put a small container under the float bowl and pop out the plug on the bottom of the bowl ( it screws out ) . You can drain some more fuel if you leave the petcock open to make sure all water is out of the system .
07-27-2009, 05:17 PM
#4 (permalink)
Thanks,I'll try both and see where it gets me.
Hap
Herd member #14
07-28-2009, 08:49 PM
#5 (permalink)
I had a tiny bit of water in the bowl.
Took it for a spin and so far so good but tomorrow I'm gonna check it again.
THANKS
Herd member #14
07-28-2009, 08:51 PM
#6 (permalink)
CHOPPA RIDN MADNESS
run super no cheap gas.
Except riding my Sled.
07-28-2009, 09:15 PM
#7 (permalink)
I've been running SHELL Premium and buying it all from the same station
Herd member #14
07-28-2009, 09:24 PM
#8 (permalink)
CHOPPA RIDN MADNESS
just makin sure man.If you have a inline fuel filter Id change it out speacialy if there was water in your bowl.then there has to be water in your filter.
07-28-2009, 09:30 PM
#9 (permalink)
I was thinking the same thing.
I have a pump with a very small hose and I thought about pumping out the tank if I find anymore water tomorrow.
Herd member #14
08-09-2009, 10:30 PM
#10 (permalink)
UPDATE
Did the sunday morning ride last week and she died again.Checked the bowl again and some more water.I had already picked up a filter so this past week I drained everything and replaced the filter.
New gas and a bit of Seafoam and the ride today was flawless.I hope I got it.
Herd member #14
| Thread Tools |
| Display Modes |
Linear Mode
