Trailer set up for Road King - Harley Davidson Forums: Harley Davidson Motorcycle Forum
post #1 of 8 (permalink) Old 01-18-2011, 01:58 PM Thread Starter
I am getting ready to purchase a 6 x 12 single axle enclosed trailer to haul my road king behind my motorhome. I am wanting to get information on weight distrubution in the trailer and where the chock should be placed for the front tire. I would also be interested in placement and number of d-rings.
Road Rocker is offline
post #2 of 8 (permalink) Old 01-18-2011, 02:08 PM
Chock: All the way forward, about 10" from the trailer's front wall. Where the axle is, and where the bike will be will end up with the bike over the axle, with the weight slightly forward. If it's a V-nose, you want the tip of the front tire at the line on the floor, prior to entering the "V", so the chock isn't mounted in the "V" part. When mounting the chock, look under the trailer and try to get the two most forward bolts through a floor support, for more strength. If not, use large washers un the underside to create more strength when mounted to the floor. I used 2" washers.
D-rings: 4, one in each corner, and as close to the front or rear of the bike's outward tire tip as you can, so the tie-off points are at an angle, and move slightly outward from the bike, and not straight up and down. It makes it more stable, and easier to handle the bike when disconnecting the tie straps.
Don't cheap-out on the wratcheting straps either. You get what you pay for and there's nothing worse then opening the trailer door and seeing a failed strap and about $1500 in damage due to a bike that came up hooked....
If you can, look at E-track, as that allows for movement and placement of D-rings anywhere you want. You screw the E-track down, making the trailer more "bike friendly" to more then just one bike, or vehicle for that matter. It mounts to the floor and allows for straps, or strap ringd to "clip in" to it and can be easilly moved. I ended up adding that to mine, after the hoops you see in each corner.
My enclosed trailer, before I sold it...
R.I.P. Rubberdown. 1971-2012
2005 E.G. Classic
S&S 510 cams
Baisley Oil pump spring
CYCO tensioners
V&H Fuelpak
SE 3.5" pipes
K&N filter
Fueling lifters
S&S adj pushrods
Swingarm stabilizer
Dave63 is offline
post #3 of 8 (permalink) Old 01-18-2011, 03:58 PM
I'm your huckleberry
facn8me's Avatar
Images: 25
Don't mean to hijack but is that a power ranger suit I see Dave?
I also agree with Dave. Weight over axle 4 straps
Never call a woman the B word. Call them BEAUTIFUL instead.. Bitches LOVE to be called beautiful!!!
Moderator is just another word for underappreciated prick.
facn8me is offline
post #4 of 8 (permalink) Old 01-18-2011, 04:09 PM
Yes...I was storing it for this guy......
Original Blue Power Ranger Reveals He Was Taunted on Set for Being Gay | PopEater.com
2005 E.G. Classic
S&S 510 cams
CYCO tensioners
V&H Fuelpak
SE 3.5" pipes
K&N filter
Fueling lifters
S&S adj pushrods
Swingarm stabilizer
Dave63 is offline
post #5 of 8 (permalink) Old 01-18-2011, 05:12 PM
and a Honda flag
Rockerbox1 is offline
post #6 of 8 (permalink) Old 01-18-2011, 05:21 PM
Originally Posted by Rockerbox1 View Post
and a Honda flag
Yep.... 2003 Honda RC51. EFI V-twin, 1000ccs, overhead cams and 127 HPs stock. Mine was no longer stock.... (Nor street legal)
2005 E.G. Classic
S&S 510 cams
CYCO tensioners
V&H Fuelpak
SE 3.5" pipes
K&N filter
Fueling lifters
S&S adj pushrods
Swingarm stabilizer
Dave63 is offline
post #7 of 8 (permalink) Old 01-18-2011, 05:30 PM
ive heard you talk about it, but this is the first time I have ever seen it
post #8 of 8 (permalink) Old 01-18-2011, 05:31 PM
the bike.... talkin bout the bike
