New front tire=spongy brakes - Harley Davidson Forums: Harley Davidson Motorcycle Forum
post #1 of 11 (permalink) Old 06-19-2017, 07:09 AM Thread Starter
old dogg's Avatar
So I R&R front wheel to have new tire mounted and balanced.
Remove calipers and wire them up to frame, reassemble without any issues and now the front brake lever needs 2 pulls to get hard.
Once it's hard it stays hard.
What did I screw up?
TIA
Tim
When life throws you a curve....lean into it.
'12 FLHTK
Stage 1 air filter
V&H power duals/slip ons
T Mann 555 cams
Dyno Tune 97HP/112Tq
old dogg is offline
post #2 of 11 (permalink) Old 06-19-2017, 07:18 AM
SCHMIDTY's Avatar
Must have spread the pads at some point, brake needs to be bled now.
SCHMIDTY is online now
post #3 of 11 (permalink) Old 06-19-2017, 07:24 AM
On the loose
67Duce's Avatar
Check your master cylinder level , it may be a little low. Also try zip tying your brake lever to the throttle grip, firmly but not super tight for 24 hours.
Other wise you will need to bleed them.
2001 Deuce , traded.
2014 Street Glide with stuff
67Duce is online now
post #4 of 11 (permalink) Old 06-19-2017, 07:49 AM Thread Starter
old dogg's Avatar
Yes I did move them in slightly. Never would have thought that would have had such a dramatic effect.
I'm do for a flush anyway.
Thanks for the info.
'12 FLHTK
Stage 1 air filter
T Mann 555 cams
old dogg is offline
post #5 of 11 (permalink) Old 06-19-2017, 07:50 AM Thread Starter
old dogg's Avatar
I'll give that a whirl tonight to see if it helps
Thanks
'12 FLHTK
Stage 1 air filter
T Mann 555 cams
old dogg is offline
post #6 of 11 (permalink) Old 06-19-2017, 08:16 AM
SCHMIDTY's Avatar
If your brakes use DOT 3 or 4 have a squirt bottle of water to flush any brake fluid off of painted parts.
post #7 of 11 (permalink) Old 06-19-2017, 08:34 AM
On the loose
67Duce's Avatar
One of the reasons for flushing brake fluid , DOT 3 & 4 , is it absorbs moisture over time causing sponginess , rust , and corrosion. Same with open bottles on the shelf.
post #8 of 11 (permalink) Old 06-19-2017, 09:31 AM Thread Starter
old dogg's Avatar
Yup brake fluid is nasty stuff.
I never leave brake fluid of any kind on shelf. When I'm done with it.....gets tossed right away.
Any way I won't have to mess with it. Bike has ABS so to the shop it goes where they have the "fancy HD bleeder dohickey".
On another note, when it comes time to change pads and the pistons need to be pushed in to allow for full thickness pads I guess I will need to make another trip to the mechanic?
'12 FLHTK
Stage 1 air filter
T Mann 555 cams
old dogg is offline
post #9 of 11 (permalink) Old 06-19-2017, 10:15 AM
Not necessarily, in fact you may not need to bleed now. use them for a few good around town days,( when you use the brakes a lot) and the problem may very well go away. Sometimes when the pads are depressed, the dust covers "hold" the pistons back and dont regain their shape until used more than a few times. After being used the dust covers regain their shape and allow the pistons to return to the proper distance from rotors. But if it's time for flushing, that will take care of it as well.
bobf is online now
post #10 of 11 (permalink) Old 06-19-2017, 12:10 PM
Evil Clown
luvstoride's Avatar
I was going to say that also. Same thing happened to me after a recent front tire change. Couple days later, no issue.
American by birth, Texan by choice.
One idiot's trash is another man's treasure.
luvstoride is online now
