Self chain oiler - Harley Davidson Forums: Harley Davidson Motorcycle Forum
 1Likes
post #1 of 15 (permalink) Old 10-15-2011, 03:32 PM Thread Starter
whavenner's Avatar
Self chain oiler
Hey does any one know if I can turn off the self chain oiler on a 81 shovelhead I just get tired of the oil spray thanks for any helper
Sent from my Motorcycle iPod touch app
whavenner is offline
post #2 of 15 (permalink) Old 10-15-2011, 03:43 PM
There's a small screw on the oil pump. turn it in. It feeds the rubber hose that takes oil to the chain.
R.I.P. Rubberdown. 1971-2012
2005 E.G. Classic
S&S 510 cams
Baisley Oil pump spring
CYCO tensioners
V&H Fuelpak
SE 3.5" pipes
K&N filter
Fueling lifters
S&S adj pushrods
Swingarm stabilizer
Dave63 is offline
post #3 of 15 (permalink) Old 10-15-2011, 04:04 PM Thread Starter
whavenner's Avatar
Hey Dave I found the screw you are talking about it seems the rear chain oiler has been caped off is there an adjustment for the primary chain oiler or is this something I shouldn't touch
post #4 of 15 (permalink) Old 10-15-2011, 05:27 PM
One fitting is for the primary, and the other for the secondary chain. The secondery chain lube screw is on the oil pump. Your manual will clearly show which is which.
2005 E.G. Classic
S&S 510 cams
CYCO tensioners
V&H Fuelpak
SE 3.5" pipes
K&N filter
Fueling lifters
S&S adj pushrods
Swingarm stabilizer
Dave63 is offline
post #5 of 15 (permalink) Old 10-15-2011, 06:11 PM Thread Starter
whavenner's Avatar
Thanks Dave for your help again
post #6 of 15 (permalink) Old 10-15-2011, 06:26 PM Thread Starter
whavenner's Avatar
One more question is it ok to adjust the primary chain oiler down
post #7 of 15 (permalink) Old 10-16-2011, 06:50 AM
SCHMIDTY's Avatar
I don't think there's an adjustment for the primary oiler . If you're still running the dry primary setup the primary is vacuum sealed and the pump evacuates the excess oil from the primary back to the tank . If that's not happening then I would suspect the primary has lost it's seal and to much oil is accumulating in it .
SCHMIDTY is online now
post #8 of 15 (permalink) Old 10-16-2011, 06:58 AM
SCHMIDTY's Avatar
Okay I'm wrong about the primary adjust screw , should be turned out about one and a half turns from seated . Found that at the S&S website .
I don't deal with chain oilers on shovels , I turn the rear chain off and I run the primary wet and block the oiler off .
post #9 of 15 (permalink) Old 10-18-2011, 08:17 PM Thread Starter
whavenner's Avatar
Ok looking into this a little more I have a 1/4 hose coming from the oil pump for the primary chain oiler I guess it's a 3/8 hose coming from the oil pump that vents to the oil tank and primary case if I cap off the 1/4 hose hose to the primary chain oiler will this help my oil spray coming off my chain or will this hurt something thanks for all your help guys
post #10 of 15 (permalink) Old 10-19-2011, 06:49 AM
SCHMIDTY's Avatar
I wouldn't cap the primary oiler off , the front chain needs lubrication or it'll break down . If the primary is sealed up correctly no oil can get to the rear chain .
