Problem with condensation in garage - Harley Davidson Forums: Harley Davidson Motorcycle Forum
Old 12-28-2011, 08:10 AM   #1 (permalink)
Hello yall.
I was wondering if any of yall have the same issue that I am trying to deal with at my house. Our dryer vents into our garage and this creates a ton of moisture if we run the dryer and keep the garage door closed...especially when it is cold outside. The other day I walked out into the garage and looked at my new ride since it was raining and I could not ride it. And it was soked with condensation just dripping from it. It seemed as if it were getting rained on. So we have since started leaving the garage door open while running the dryer, but I was wondering if anyone else has a permenant solution to this problem. The dryer vent is on the opposite side of the garage that the motorcycle and there are two windows that are on the same side as the motorcycle...do yall think I should open these two windows and keep them open at all times? Or will that just let too much cold/hot air in and out of the garage when the dryer is not running?
Any thoughts would be greatly appreciated.
Peavley is offline   Reply With Quote
Old 12-28-2011, 08:15 AM   #2 (permalink)
SCHMIDTYS's Avatar
IMO , add some length to the dryer vent and run it to the outside of the garage .
Old 12-28-2011, 08:19 AM   #3 (permalink)
Curmudgeon
scol's Avatar
Images: 57
I was in the appliance repair business for 35yrs. one of the worst things you can do is vent your dryer into the garage .
1. If it's gas = carbon monoxide
2. Electric it'll create mold and if allowed, it can build to dangerous levels
3. The damp conditions well effect all electric and mechanical objects being stored in the garage, even the fuse box if it's there.
Solution is to vent properly to the out side.
“Never kick a fresh turd on a hot day.”
― Harry S. Truman
They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety
Benjamin Franklin
scol is offline   Reply With Quote
Old 12-28-2011, 08:34 AM   #4 (permalink)
A Dog Chasing Cars
2stangs8689's Avatar
Images: 5
I had this same problem, I moved dryer to other side of basement, and vented it outside.
Forum meet info...Keep an eye on the first page, first post, of thread for updates....Link is below.
http://www.harley-davidsonforums.com...t-collide.html
If you have not signed in for the Forum meet and greet, and want to attend, please sign in here...
http://www.harley-davidsonforums.com...se-thread.html
2stangs8689 is online now   Reply With Quote
Old 12-28-2011, 08:41 AM   #5 (permalink)
harvey13118's Avatar
As said: vent it outside. DUH!
Life: VFW, NRA, NYSRPA(NYS Rifle Pistol Association)
2 favorite signs
CAUTION we do not dial 911 first.
DANGER if you are reading this U R in range.
05 FLSTC, 08 FLHTCUSE3
harvey13118 is offline   Reply With Quote
Old 12-28-2011, 08:51 AM   #6 (permalink)
2008 Heritage
MDGeorge's Avatar
What if you vented it into the attic? if it won't reach the outside.
Taming the Beast
MDGeorge is online now   Reply With Quote
Old 12-28-2011, 08:59 AM   #7 (permalink)
Curmudgeon
scol's Avatar
Images: 57
Thats worse the moisture and monoxide= trouble! outside,outside,outside
― Harry S. Truman
Benjamin Franklin
Old 12-28-2011, 09:02 AM   #8 (permalink)
2008 Heritage
MDGeorge's Avatar
You could vent it through the roof.
Only if you can't run it outside.
Taming the Beast
Old 12-28-2011, 09:08 AM   #9 (permalink)
SCHMIDTYS's Avatar
I'm guessing they have a first floor laundry and the inside door from the garage into the house goes thru the laundry room and they just vented the dryer thru the wall into the garage . If that's the case I would install a vent out the laundry room wall to the outside and plug the hole to the garage .
Old 12-28-2011, 09:12 AM   #10 (permalink)
SCHMIDTYS's Avatar
Peavley you should go into your User CP and change your personal info , it's still got you as not having a motorcycle !!! ...
