You're at work &...... - Harley Davidson Forums: Harley Davidson Motorcycle Forum
Old 11-15-2012, 07:51 PM   #1 (permalink)
......you get on your bike (EFI) to return home and it doesn't turn over. Battery is low..... what are the options for getting it started.
I hear (as I've always had carb-bikes) that it is very difficult to "roll-n-start" an EFI bike. True? Any tricks here? Or is getting a jump the only option?
bradahj is offline   Reply With Quote
Old 11-15-2012, 07:58 PM   #2 (permalink)
nipplesurfer's Avatar
The reason an EFI bike is hard to roll start is that without electricity there's no fuel pump, therefore no fuel. If you do get enough juice to cycle the pump you should be able to do it.
nipplesurfer is online now   Reply With Quote
Old 11-15-2012, 08:02 PM   #3 (permalink)
EVO snob
gtrman66's Avatar
I've done it. You can roll start an EFI, hard but possible.
Riding Baggers before Baggers were cool!
1995 FLHT "GG I" 127k miles - RIP (1997-2010)
1997 FLHTC, "GGII" 126k the "new" bike (2011-Inifinity)
http://www.doolinband.com - the band!
gtrman66 is offline   Reply With Quote
Old 11-15-2012, 08:03 PM   #4 (permalink)
Key on, second gear, push and pop the clutch.
fxrglide91 is offline   Reply With Quote
Old 11-15-2012, 08:07 PM   #5 (permalink)
Harley Rider
TmikeX's Avatar
Images: 11
jumper cables
2013 FLHTK
"I keep trying to think but nothing happens"
- Curly Howard
TmikeX is online now   Reply With Quote
Old 11-16-2012, 08:22 AM   #6 (permalink)
chasarms's Avatar
Originally Posted by TmikeX View Post
jumper cables
I agree. Unless conditions are ideal, you probably won't be able to get enough fuel pressure to jump the bike.
2005 Electra Glide Classic FLHTCI
Black Cherry Pearl
chasarms is offline   Reply With Quote
Old 11-16-2012, 08:31 AM   #7 (permalink)
SCHMIDTYS's Avatar
If there's any volts there the fuel pump should run, if there's lights the pump will run. Get a push and bump start the bike. Next find out why the battery is low. Don't just charge the battery and go again. Do the battery and charge system diagnostics.
Old 11-16-2012, 08:53 AM   #8 (permalink)
Ray-zer's Avatar
I had heard somebody else saying to put it in second gear a while back. Why is that? Why not first?
Ray-zer is offline   Reply With Quote
Old 11-16-2012, 09:00 AM   #9 (permalink)
SCHMIDTYS's Avatar
To low a gear, the rear tire will just skid. Even 3rd gear will work well.
As soon as the engine catches pull the clutch in and keep the engine running.
Old 11-16-2012, 09:37 AM   #10 (permalink)
hogcowboy's Avatar
Images: 3
I actually think second gear is too low a gear.
Do everything like your life depends on it. It could.
Patriot Guard Rider
hogcowboy is online now   Reply With Quote
