Non ethenal gas - Page 3 - Harley Davidson Forums: Harley Davidson Motorcycle Forum
Old 12-06-2012, 08:24 AM   #21 (permalink)
'11 SuperGlide FXDC
Wrgiacona's Avatar
Originally Posted by ponowai View Post
Been using non ethanol gas in my 06 FXDI for two months, I like it. The octane rating is only 89 but it runs good. Biggest difference I notice compared to e10 is it runs cooler. That alone makes it worth the extra coin, to me.
You should be seeing an 8-9% increase in MPG as well.
Wrgiacona is offline   Reply With Quote
Old 12-08-2012, 12:48 AM   #22 (permalink)
You're probably right but I don't keep track of my mpg.
ponowai is offline   Reply With Quote
Old 12-08-2012, 02:07 AM   #23 (permalink)
mrmetal's Avatar
Originally Posted by petew View Post
Try finding the place that sells racing fuels, United Oils here in Boise carries at least 3 different levels of octane and no alcohol. I mix the 110 leaded with the 87 unleaded without alcohol, one gallon racing fuel to every four of the cheap stuff. This gives me a 93 octane without alcohol. Works great for the work and shopping etc., on the road, it is Chevron and it's highest octane sold whenever possible.
A tank of the 110 does make a noticeable power level increase, but at $8 a gal, too expensive for me! I think it makes the higher compression in my bike with it's stage IV state.
DON'T put leaded fuel in your bike if you have oxygen sensors. It does screw up the oxygen sensors. And it doesn't take long.
Grain–Dial petroleum 2757 S Federal Way in Boise has 91 octane with no alcohol.
Old 12-08-2012, 08:10 PM   #24 (permalink)
I am new to the HD world and I only see E-10 in my area, should I get a fuel treatment if it sits?
Vandy58 is offline   Reply With Quote
Old 12-08-2012, 08:15 PM   #25 (permalink)
I just checked, nearest pure is 130 miles away
Old 12-08-2012, 10:09 PM   #26 (permalink)
If you use up the fuel in 2-3 weeks it shouldn't be a problem, longer than that and stabilizer is definitely required. Steve Garns (Brew Dude) did a couple of excellent articles in the The Horse BC on the effects of E-10 after only a couple of months of storage.
chris_lacey is offline   Reply With Quote
Old 12-08-2012, 10:43 PM   #27 (permalink)
Retired firefighter
KMAN96ULTRA's Avatar
I've been using shell v-power in my 96 and sea-foam no problems.
Still UP-RITE....and PUMPING AIR
A old scout once said...Lead...Follow...or get the hell
out of the WAY
KMAN96ULTRA is offline   Reply With Quote
Old 12-09-2012, 08:33 PM   #28 (permalink)
Originally Posted by OZNOG View Post
I as well as everyone around here in the know, marinas, bike shops, etc. change over everything that sits for extended time to non-alcohol fuel before storage.
The preferred additive is Star Tron Enzyme Fuel Treatment. (In the blue bottle)
Picked some up, thanks
