FXRS Ignition Switch Removal - Harley Davidson Forums: Harley Davidson Motorcycle Forum
Old 11-21-2012, 04:10 PM   #1 (permalink)
bikedelic's Avatar
Exclamation FXRS Ignition Switch Removal
Does anybody know how to remove the bezel/lock ring that holds the ignition switch in the bracket on an FXRS.
This bracket is welded to the frame, there is a small hole in the bottom of the switch, which I presume has some kind of a setscrew in it but I haven't had any success removing it and I can't see up into it because of its position. I thought it was a #27 torx, but that slips in the hole.
I need to remove the switch to remove the rear cylinder. Help please!
Thanks and Happy Thanksgiving
bikedelic is offline   Reply With Quote
Old 11-21-2012, 05:18 PM   #2 (permalink)
bikedelic's Avatar
I got it - no set screw - red loctite on the bezel - switch out.
Old 11-21-2012, 05:23 PM   #3 (permalink)
tattoo judge
dmwphoto's Avatar
glad you got it sorted
Dave
http://dmwphoto.smugmug.com
dmwphoto is offline   Reply With Quote
