%&@#*!!!! - Page 2 - Harley Davidson Forums: Harley Davidson Motorcycle Forum
Old 11-28-2012, 09:25 PM   #11 (permalink)
2010hdultra's Avatar
I had a 2010ultra stock 96 and rinehart slipons and stage 1air cleaner. I got 45-50 all the time. Sounds like to me the factory efi is running to rich since you took out the o2 sensors. The pcv is just a piggy back system that tricks the stock efi into running what the pcv tells it to. The map on the pcv is running on top of the factory map. If your efi doesnt receive a signal from the o2sensors then its probably runking rich and then the pcv tells it to run even richer. Without the o2 sensors you are pouring fuel down the exhaust.
2010hdultra is offline   Reply With Quote
Old 11-28-2012, 10:05 PM   #12 (permalink)
Knash's Avatar
Question: I know that the recommendation is 91 - 93 octane fuel which I use (sucks paying 40c more a gallon) but would this make a difference if you didn't have premium and then got the bike dynoed?
Let's ride, I mean let's just ride!
2012 Ultra Limited
Life Church Riders Group Germantown WI
Riding with our Lord!
Knash is online now   Reply With Quote
Old 11-29-2012, 07:39 AM   #13 (permalink)
TinyPeckerwood's Avatar
not quite how it works. Bike runs on PCV map, 02 sensors are eliminated with the PCV. The mapping in the PCV needs to be adjusted.
2010 FLHX Denim Black
103" stage II
SE 255 cams
Vance & Hines Black Radius Shots
Power Commander V w/ auto tuner
Oil bud cooler
2005 Deluxe blue & white(hers)
Operating Engineers Local 12
TinyPeckerwood is offline   Reply With Quote
Old 11-29-2012, 08:49 AM   #14 (permalink)
'11 SuperGlide FXDC
Wrgiacona's Avatar
Octane is a rating of the fuels anti-knock properties. You can't Dyno out the fact that your bike has a high compression engine and needs the higher octane fuel.
Does it need premium instead of maybe the mid grade stuff? That is a whole other question.
Wrgiacona is offline   Reply With Quote
Old 11-29-2012, 09:34 AM   #15 (permalink)
bgdv1's Avatar
My 11sg has a stg2 103 screamin eagle kit, 255 cam, decatted pipes w/ 4" se slip ons, se ventilator and seprt. I average 40 mpg +/- riding 2 up depending how hard were running and who were riding with.
2011 black denim SG,SE 103 w/255 cams, SE ventilator,decatted header pipe,SE 4" pipes, SEPST, lots of xtra chrome,ipod,garmin 255W, 19"/18" contrast chrome agitators
bgdv1 is offline   Reply With Quote
